Question about Tefal Kitchen Appliances - Others
Change frequancy 60hz 50hz - Tefal Kitchen Appliances - Others
Benimur
  • 6966 Answers
SOURCE: 50Hz to 60Hz conversion
Hi, Your idea is basically sound and should work as long as the UPS originally is designed to produce 240V 60Hz and has its own built in timebase. The reason is that the input as long as the voltage matches makes no difference (50 or 60 Hz). By design, the UPS converts the input voltage to DC to charge the internal battery. The battery then powers an electronic circuitry that produces the 240V 60Hz. The input is then isolated from the output in terms of frequency. This is a common design, however, there are some (not many) that uses for its local oscillation sampling from the source and therefore will replicate the input frequency to its output, but very rare; it's better that you know they exist. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards. P.S. The only problem with 50 and 60 Hz is heat buildup which is tolerable and still within safe parameters. The only time the 50/60 HZ makes a big difference is when motors are used, timers such as in the early designs of microwave ovens, washing machines, etc., pumps and other highly inductive consumers. Most electronic devices converts the AC input to DC and therefore the frequency has negligible effect. Of course others may see it differently.
Posted on Sep 16, 2007
SOURCE: bose clock radio Awrc-1p
Call the US tech support line, they will talk you through it.
Posted on Sep 26, 2007
rowdy45176
  • 2176 Answers
SOURCE: Will DeWalt charger work on 120V 50Hz?
I don't think that would be a problem, For schematics I would go to Dewaltservicenet.com and type in your model number usually in the center of the site and download a breakdown. Let me know if i can help more.
Posted on Feb 13, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Just bought a Maytag MDB8959AWB
Hey i am sorry i got disconnected could you please reconnect to the chat room or just post me and i will give you the solution there \
best regards mike
Posted on Jan 23, 2010
Testimonial: "Very helpful and intrested in the problem. I could not stay awake any longer so I will be back."
  • 122 Answers
SOURCE: Samsung LCD TV series 5 240Vac, 50Hz will it work with 60Hz?
no only the voltage is critical.the only point is you have to select right counrty and tv sound and picture system on setup menu!
Posted on Jun 06, 2010
Can i use a 50hz 220V SPLIT TYPE AIRCON TO 60HZ 220V
you probably can but it will be damaged over time, you would need to replace the motor inside to handle 60hz using the 50hz can do damage to the motor, or even cause a fire. also if it has a power capacitor that asys 50hz on the power line to the unit inside this would been changing as well.
Jun 29, 2017 | Heating & Cooling
How to operate a AEG Washing Machine Electrolux 50hz with 60hz power supply?
In general, it is NOT recommended to operate an appliance 50hz-to-60hz OR 60hz-to-50hz UNLESS the manufacturer specifically says it can do it.
Additionally, you must also account for the voltage (110V vs 220V), which you have not indicated.
Therefore, it is best to get your exact model number and contact the manufacturer, but get ready for disappointment. The larger and more complex the electronic device, the less compatible it is.
Good luck.
Mar 19, 2015 | Electrolux Washing Machines
Have paint spraygun 60hz. want to use it in 50hz area. what can i do
Unfortunately, products are designed to work with specific voltages and frequencies. Some devices have broader ranges of voltages and frequencies because they use electronic power suppies (often called "switching power supplies") as opposed to the costlier, heavier transformer types. Nearly all devices that have motors or have a transformer will be designed to operate on either 50 or 60 hertz - not both. Use of these devices with a frequency other than what it is designed for will run too fast / too slow and will overheat to the point that it may become a fire hazard. Unlike voltages that can be easily stepped up or down with a transformer, there is no easy, inexpensive way to change frequency.
You should replace your "60Hz only" equipment with 50Hz or 50/60Hz equipment, or if a short term relocation, rent the correct 50Hz equipment instead.
I hope this helps & good luck!
Dec 13, 2012 | Garden
Can lg 50hz washing machine run on 60hz
yes but I will not good IDEA you will have phenomen transistory is electrical term in engineeering electric, you must get support via ONLINE chat or phone with LG.
you must transform the 60hz to 50hz or 50hz TO 60hz.
God bless you
Sep 30, 2012 | LG WM-1832C Front Load Washer
Bought a singer from the state but cannot be used in australia what should i do?
If it is an electronic or computerized machine, you are out of luck. USA has 110 volt 60Hz current, Australia has 220 volt 50Hz. A transformer can change 220 to 110 volts, but it cannot change 60Hz to 50Hz.
Sep 21, 2011 | Singer 4423 Sewing Machine
The horizonal hold is not working it rolls up and down
I understoof about your problem of Mitsubishi CS-35503* TV , I think you should change your interlace scanning frequancy by remote control t0 50Hz
if there will not effect then change your horizontal hold IC
Thank you!!
give your rate!!!
Feb 20, 2011 | Mitsubishi CS-35503 TV
Covert 230V 50Hz to 230V 60Hz
To convert to 50Hz will be expensive as the Aircon needs alot of startup power. You could ask maker if 50Hz will be ok, usually motor will run slower so unit will be less efficient, alway check with maker. Or try supplier to see if they will exchange for what you ordered first.
Dec 18, 2008 | Liebert UPStation GXT2700RT-208...
I have magnavox TV
you will need an adapter for it....
its the current frequesncy what he told you.. in US they use current of 60hz frequecny....
the place you live in use 50hz.. that is the reason...
see this link...it wil help you surely..
50hz to 60hz - For: 1.Use overseas to test products destined for use in the US or other 60Hz countries;
2. To operate 60hz machinery from a 50hz utility.
Jan 19, 2008 | Philips Magnavox 51MP392H Rear Projection...
60hz to 50 hz
No need to worry about that. The direct drive on these turntables will adjust for hz setting automatically.
Jan 10, 2008 | Technics SL-1200MK2 Turntable
Kitchen Appliances - Others Logo
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
