Question about TAB - Taiwan Always Best Android Apps
What does setting mean
I don't know what setting mean can you help me
Why im on Ask not google?
if you mean when searching in the address bar or "omnibox" as they seem to call it:
click the three lines at the top right corner, settings, (a new tab will open), the 4th group down is Search, you're set to Ask, just change it to Google. Just close the tab, it saves the change instantly.
If you mean the home page, also go to 3 lines, settings, and the second group "on startup" select "open a specific page or set of pages" and then click Set Pages. hover over any pages you don't want to open at startup and click the X to remove, and in the box for Add New Page, enter http://www.google.com/ then click ok, and close the tab.
If you mean something else, let me know exactly what you want and I'l try to help.
Oct 22, 2014 | Google Chrome
2004 nissan frontier heater blower fan does nothing on setting 1,2,3, works on 4
This condition usually means a bad fan speed control. Unfortunately I don't know where the unit is located on this car. Dealer might help with location.
Jul 30, 2012 | Nissan Frontier Cars & Trucks
How do set bios password
If you don't know what it is, then you definitely don't want to set a password on the bios.
May 02, 2012 | Dell Latitude D630 Notebook
How can I Disasemble my ge microwave it has weird screws
those are security screws so that folks that don't know about microwave don't get bit by 4000 volts. IF and i do mean IF you know what your doing you can go to ace hardware and buy a set of bits that will open them.
Jan 03, 2012 | GE Microwave Ovens
I want to know how to connect my ssid pasphrase located on the back of my router and when i tried to conect it to my ps3 conole it said it was weak and it couldnt find the acess point or something so can...
i'm going to assume that you are asking "how to connect your ps3 to your home network?"
if your home is set up with wireless modem or router and your computers are connected wirelessly its pretty simple to set up. more likely you or someone who set it up probably set it up securely meaning with security key and password. So you do have to know few things about your home network. like what is the name of your home network (SSID). the security setting of your home network. and finally the password of your network. if you don't know these things about your home network you will not be able to get connected wirelessly. but if you do have these info on hand read along....
JUST MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont work if you don't have a wireless setup and u are trying to connect wirelessly. people overlook this no brainer.
Turn on your ps3 and from the XMB...
1) go to Settings
2) Scroll down to Network Settings and press X
3) Scroll down to Internet Connection Setting and press X. confirm on "O.K."
4) easy *it may or may not give you a message reading "checking network configuration"
5) wireless
from this point on you need to know few things about your network.....
6) scan -- once scanned it'll give you wirelss access point for you home network and some other near your home along with few information such as....
...SSID (which is what you set your network to be -- i.e. "the jones" or "linksys" or "summer home" or "my connection" etc etc) ...SECURITY (this is the password you set up your network with) ...SIGNAL STRENGHT (usually your network will be the strongest among your neighbors since you are closer to your router)
7) highlight your network and press x . (you should know what it is) selecting on the other network probably wont do you any good since it'll probably be all locked with password and such. yours should also be locked and have password on it too.
8) SSID which means service set identifier basically mean the name of your network. if your home network is set up with security and password your home network will not show up under SSID (this is one of the things you need to know about your home network. if you don't know ask the person who set up your home network)
9) on WLAN SECURITY SETTING page (this is another thing you should know about your home network or ask the person who set it up) -- most people i deal with have a WPA-PSK / WPA2-PSK security password. Yours may be different so choose the one that you used.
10) WPA KEY - which basically means password. input the password you used to set up your home network (this is another thing you should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input all the correct info you should get the "setting list" screen
12) press "X" to save the setting
13) do the connection test and if all things were entered correctly you should have success.
all this seems complicated just reading but if you follow it step by step its easy. you just need to know the name of your home network, the home network setting, and the password of your home network.
on the other hand if you are setting up a wired connection it makes it a whole lot simpler. you don't need to know your network name, security key, and password.
make sure you have the ethernet cable plugged in to your ps3 and to your modem or router
1) go to Settings
2) Network Settings
3) Internet Connection Setting. confirm on "O.K."
5) wired
6) auto-detect
7) automatic -- for the IP address setting
8) do not set
8) automatic -- DNS setting
9) automatic -- MTU
10) do not set -- PROXY SERVER
11) ENABLE -- UPNP
save connection setting
test connection
if your home network is set up and u got the ps3 connected it should work
Sep 01, 2011 | Sony Playstation 3 (PS3) Console
I would like to know the meaning of error code :051312-1 thanks
I don't know the meaning of the code directly, but I got around it by setting up MAC filtering on my router (you go into your router's settings, get your DSi's MAC address, which you can get if you go into the system information, and add it to your router.
Don't know if it'll work, but it helped me.
Jul 15, 2011 | Nintendo Video Game Consoles & Games
I have my new samsung corby 2 gt-s3850. there's an "e" icon or the edge network appeared on my fon.. does it mean that im still connected to internet? i'm worried because i don't know...
No your phone is not connected. The 'e' means that your phone is internet connection on it, that is you can use your phone to browse on internet. So , do not worry yourself.
To get the phone profile, scroll to phone setting, press okay and scroll to phone profile. Regards.
Jun 19, 2011 | Cell Phones
Help Unlooking Audiovox PVS72901
TRY THE DEFAULT CODE 0000 OR 1234 IF THAT DON"T WORK IM SORRY THAT I CANT HELP YOU WITH THIS
JUST GO TO SETTINGS ON THE DVD PLAYER
Jul 01, 2008 | Audiovox PVS72901 Portable DVD Player
Lexmark e330 doubts
Please use this link it may be helpful:::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi
Feb 26, 2008 | Lexmark E330 Laser Printer
Android Apps Logo
Top TAB - Taiwan Always Best Apps Experts
Brett Duxbury
Brett Duxbury
Are you a TAB - Taiwan Always Best App Expert? Answer questions, earn points and help others
