Causes buzzing in head
Buzzing head noises,especially at night
  • Audio Player... Master
  • 1,267 Answers
Buzzing in head at night may mean you are using a lighting system with a fader or a Triac controlled output. These put all kinds of garbage on the electrical lines that will get into audio system. Without more information about your problem this is only a guess. Model number brand and other things noted.
Posted on May 08, 2014
How to determine the cause of lack of fuel inside the fuel system
turn the key and listen for a buzzing noise if no noise fell pump is bad, possibly a clogged fuel filter or pick up screen on the fuel pump.
Feb 24, 2015 | Sylvania Osram Diadem Py21w Front...
The head of my madal is buzzing
I just found this website, so sorry for the delay. sometimes the heads (especially plastic or composite) come partially unrolled from the rim to which they are attached. since by tuning it, you are pulling the head tighter only because it's firmly attached to the rim, if the rim is loose at even a little spot, that place will sound funny. you might get a crackle or buzz where the fit just isn't right. plus, in this case, if you keep tightening the rest of the head, this portion will just warp or fold since it's not tight enough to lay flat and stretch, which will just increase your noise.
Now, if the head's leather, the buzz might be a fly trapped inside. no really, check for splinters or separations on the rim of the body which the head is stretched over. if there is a split in the actual drum body, you'll hear it more when the head next to it is vibrating.
Jan 13, 2013 | Mid East Madal Strap Tension Drum
My Quinny Buzz creaks and squeaks all the time, especially on long walks. It sounds like the noise is coming from the plastic housing where the seat clips on. Is there anyway to solve this annoying...
Good Morning
If the Buzz chassis is definitely correctly unfolded and locked into position and you hear these noises it should come to the engineers for full inspection.
Sometimes people force the chassis into the fold position without correctly unlocking it first and this can break the knuckle joints, causing noise when in use. If you're satisfied you haven't done this, full inspection and any repair work required will be covered under warranty if the product is under 2 years old - simply return it to your retailer with your proof of purchase.
Aug 07, 2011 | Quinny Buzz Three Wheel Stroller
I have a proscan 42LA45H 42 in television that has started making a buzzing noise from the back. What is causing this, and what do I need to do to fix.
Hi
If picture and sound is Ok, and only this buzzing sound is heard from the back of the TV, It should be due to core soose of some ferrite cored transformers inside, especially to the power supply regulator board of the TV. Open the back cover of the TV and swtich it ON. Listeen very carefully which transfromer makes the buzzing noise. Just trouch and press the core of the transformer suspected with some non-cunductive material like glass rod, or a stick of dry wood. You can identify the transformer that makes noise by this way. After identifying the exact transformer; switch OFF the set, unplug it from mains socket, apply some "Super Glue" like fast boanding glue to the joint of core of that transformer. Allow sometime for the glue to set. This will solve the buzzing sound problem of your TV. OK
Jul 13, 2011 | Proscan 42LA45H 42 in. LCD TV
2007 Volkswagen Golf Sport GTI 1.9 - Humming noise I bashed my car in works car park by hitting the pavement with all the ice and snow we've had. That night as I was driving back it made a slight...
I suggest having the front suspension immediately inspected for damage, especially something that could be repaired before causing more damage. It appears that it may, at the minimum, be out of alignment and at worst, the axle and/or frame nay be bent.
Apr 05, 2017 | 2000 Volkswagen Golf
My portable electohome radio model EA15OK sitting on my night table makes a loud buzzing noise when my light is turned on.
It sounds like you understand the mode that causes the noise. What kind of light is it? Some lights emit RF so it wouldn't be a mystery that a radio would pick it up.
Dec 27, 2010 | Audio Players & Recorders
Humming sound coming from the small speaker over my head ?
That "speaker looking thing" above the drivers head on the headliner is a part of the climate control system.
Here is the GM bulletin regarding it if you are running in to these issue:
Document ID# 1639237
Subject: Buzz Noise From Headliner Above Driver - keywords ac air aspirator cover fan grille HVAC interior microphone sensor speaker temperature vent vibration #PIT3511 - (03/29/2005)
Models: 2000-05 Cadillac Escalade
2002-05 Chevrolet Avalanche
2000-05 Chevrolet Silverado, Suburban, Tahoe
2000-05 GMC Sierra, Yukon, Yukon XL, Yukon Denali
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in the PI.
Condition/Concern:
Dealer or customer may comment that they have a buzz or vibration noise emanating from the headliner in an area that looks like microphone or a speaker.
Recommendation/Instructions:
The plastic escutcheon grill, which is round and about the size of a half dollar and located just above the driver to the left, is the interior ambient temperature sensor. The sensor is used in conjunction with the automatic HVAC (C68). On occasions, this sensor has been known to make a buzz or rattle sound. The sensor uses a small fan to pull air over the sensor. This buzz noise may be intermittent.
Although it may not be possible to alleviate all of the buzz or noise from this sensor, Engineering has found that if the sensor is installed incorrectly that it may bind and cause the fan to make a buzz noise. Remove the sensor and while doing so check for any binding. Reinstall the sensor and re-test. If the noise is still present, the sensor itself may be noisy and require replacement.
Mar 31, 2010 | 2004 Chevrolet Silverado 2500HD
My toshiba makes a buzzing noise when the colour
you will need a power board the laninat in the power transformer is vibrating causing your buzz wine
Nov 02, 2009 | Toshiba REGZA 32XV515DG 32 in. LCD HDTV
Refridgerator is clicking on loudly then buzzing and sizzling
I bet the Iemaker arm has been turned on allowing th eicemaker to cycle every 10-15 mins when the icemaker calls for water it causes the water valve to open. with no water connected to the unit the valve buzzes loudly causing your noise. make sure the icemaker arm is in the up position thus turning the i/m off thanks peyton
Mar 22, 2009 | Refrigerators
Whirlpool AWO/D 6507 (I think - at work currently) Fault details: Failed part was through a wash now has - Low mechanic buzzing sound when cycle started. Drum will turn by hand, but not by...
Fixed it!
drained (via filter) last night, took out the missus's hairclip which was jamming the pumps (which was stopping it from spinning and causing the buzzing noise) and all good!
saved a few pennies!!
Aug 19, 2008 | Whirlpool Washing Machines
134 people viewed this question
 Grubhead
Grubhead
