Question about Delphi SKYFi3 XM Radio Receiver
Screen is frozen & none of the buttons are working, what should I do?
I've tried to reboot, and it won't work.
How can I get my mail through my app
Sounds like you need to do a hard reboot. From Google:
Here's how to perform a hard reboot:
- Hold down the Power and Home buttons at the same time for close to 10 seconds.
- Ignore the Slide to Power Off bar across the top of the screen when it appears and just keep holding the two buttons until you see the iPad screen go black and then see the Apple logo on the screen as it restarts.
Hope this helps!
Apr 11, 2016 | Apple iPad 2 Wifi 16GB
I have a toshiba satelite L655-s5117 laptop and it won't boot up even when i try and boot from windows 7 disk it won't
Probably a faulty hard drive. go into the setup screen and verify the HD setting is correct. save your settings and reboot. if this doesn't solve it, then take out battery and disconnect power, remove hard drive and reconnect. try reboot. if none of that works, then replace hard drive and reinstall OS.
Mar 10, 2013 | Computers & Internet
Won't charge
You have a Dead Kodak !!! needs to go to shop.
Sep 24, 2012 | Kodak EasyShare M532 Digital Camera
My nook color has frozen screen and won't shut completely down
TRY a hard reset on the Nook if that doesn't work i know of this fantastic site BNTPrice.com that sells them for cheap. i hope this works for you
  1. Press the "n" button to display the quick nav bar.
  2. In the quick nav bar, tap the Settings icon.
  3. In the Device Settings section, tap Device Info.
  4. Tap Erase & Deregister Device.
  5. Stop. Think. Think again.
  6. If you really, really want to do this, go to Step 7. If not, tap the Back button.
  7. Tap the Erase & Deregister Device button.
May 24, 2012 | Barnes & Noble Nook Tablet
I have a Sony Eplod MEX-BT2800, all of a sudden the buttons/functions won't work, I currently have a CD in the player, the buttons to skip songs won't work and I can't even eject it. Also I...
Hi i removed the positive on the battery terminal and tried the stereo still no buttons work although the source button and volume work but thats it any ideas thank you
Jul 06, 2011 | Sony MEXBT2800 AMFMCD Car Stereo Receiver...
Behringer Bass V-Amp
In my xvamp, a strucked microbutton caused E2. I've replaced the button, and everything went right :D
Nov 29, 2008 | Behringer F-CONTROL AUDIO FCA202 External...
Creative Zen Micro (6gb) is frozen
Take your battery out of the back, turn it back on and let it reboot.
Jul 28, 2008 | Creative Labs Zen Micro MP3 Player
IPod click wheel frozen
Try to restart the Ipod.
Hold the select button and the menu at the same time until you see the screen go off.
If still does not work then try to enter disk mode and see if it works.
Disk Mode:
Reboot the ipod via Select and menu, right away hold the select and play button and hold until disk mode comes on. Does the wheel work?
If still does not work then reboot the ipod again and let it reboot normal to go back in apple firmware. If all buttons are working and none of the above works, I would assume it is not software related.
Nov 12, 2007 | Apple 20gb Ipod Mp3 Player With Click...
Delphi SKYFi3 XM Radio Receiver Logo
99 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
