Question about Health & Beauty
What causes My rose bushes to develop brown spots on the leaves. The leaves turn brown and drop off,whHow do I treat them?
  • 188 Answers
SOURCE: Dryer leaves brown spots on clothing articles.
With the combination of seal gaps and brown spots (streaks) on your clothes, chances are the front (part # 3406129 ~ $26) and rear (part # 279857 ~ $17) drum seals need to be replaced. Run a rag around the seals and check the marks to confirm this is the problem.
Depending how big the gap is, you may need to replace the drum support rollers if they are worn (part # 349241T ~ $24).
The parts are available at Sears. Labor costs will vary depending on where you live and if you're not replacing them yourself.
Let me know if you need more help or information.
Posted on Mar 23, 2009
SOURCE: leaving brown stains on clothes, messing them up,
If it isn't rust, I suspect cotton can decompose if moist for a long time (in the laundry or machine), causing brown spots. In that case, the spots probably cannot be removed. Or can they?
Posted on May 23, 2010
  • 1456 Answers
SOURCE: roses bushes are stunted with
Hello
When down near the ground level make flush cuts at the bud union area so stubs aren't left to begin health issues.
Cut just above the bud at a 45 degree angle going away from the bud. Getting too close to the bud can kill it so adjust to cut just above it. When cutting watch the center of the tissue and prune back to where it's clean, white tissue. Especially in cases of older woody canes, there sometimes are brown spots in the center of the cane. Cut back to where what remains is solid white center.
Posted on Dec 26, 2010
  • 961 Answers
SOURCE: I do not know when
Fertilize them and make sure they have plenty of water after fertilizing. It's bset to have mulch around them at this time of year. You can cut them back some, depending on size but, leave enough to give shade beneath plant for the roots. Best time to trim them would be spring, before the major heat. You don't want the root system soaked all the time so, with the mulch, maybe water every other day, in the morning, to let water soak in and dissapate.
Good luck,
Dave
Posted on Jul 16, 2011
sandy_wil290
  • 473 Answers
SOURCE: How do I treat Big Bud on blackcurrant bushes ?
try using a dishsoap mixture with water - more dishsoap than water though
Posted on Nov 20, 2014
I HAVE CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP
Have a read. Disease, pests or virus.
Grape Diseases and Drying on the Vine ' Home Guides ' SF Gate
homeguides.sfgate.com > Garden > Pest Control
  1. Cached
  2. Similar
The leaves become mottled with tiny black spots and the fruit also bears dark spots. ... Most of the diseases that cause drying grapes on the vine are fungal ...
Why Are the Grapes Dying on the Vine? ' Home Guides ' SF Gate
  1. Cached
  2. Similar
Luckily, the fungi, insects and bacteria that cause fruit to rot or wither are easily ... Summer bunch rot-infected grapes have black, brown or green powdery fungal ... Removing leaves at the base of stems once grapes have set helps control both ... Best Time to Pick Concord Grapes for the Best Flavor ยท Grapevines & Leaf Curl ...
What Are the Causes of Grapes Turning Black Before They Ripen ...
  1. Cached
  2. Similar
If your grapes turn black on the vine before they ripen, the cause is usually black rot. ... which helps prevent infection by speeding the drying of leaves and fruit.
Why are my grapes turning dark and drying up before they ripen ...
https://ask.extension.org/questions/199835
  1. Cached
  2. Similar
Jul 16, 2014 - Minimize black rot problems by removing infected fruit, cleaning up mummies, and pruning out leaves that surround fruit clusters. See fruit links ...
Grape Diseases ' Integrated Pest Management Program - MSU IPM
www.ipm.msu.edu/grape_diseases
  1. Cached
Oct 16, 2014 - Leaves develop numerous dark brown spots, 1/25 to 1/5 inch (1 to 5 mm) in diameter. ... resulting in distinctive clusters of dead vines within the vineyard. ... Berries that do not fall off shrivel up, similar to black rot-infected berries. .... This disease occurs only in Concord and Catawba grapes in Michigan.
CONCORD GRAPES THE FRUIT DIEING ON VINE AND LEAVES ARE DRYING UP Google...
Aug 14, 2017 | Cooking
My forever roses were beautiful but this spring I noticed black spot o the stems and fluffy leaves and flowers
Fungal disease forms black spots all over the foliage of rose bushes.
Remove as much of the affected plant as possible then treat it with a fungicidal spray.
Repeat the treatment every ten days until the disease has been eradicated..
Apr 15, 2017 | Garden
What causes rose leaves to turn yellow?
If you're asking about something to do with a sewing machine, I'm not going to be helpful, but if you're asking about rose bushes, then read on.
Yellow leaves can be caused by the soil pH being too far off what roses like. Slightly acidic is what they want. Alkaline is typical of many locations where roses don't do well.
Iron deficiency is another reason for yellow leaves. Often caused by alkaline soil.
Apr 18, 2015 | Sewing Machines
I need to know how to treat pecan tree fungus, any ideas? I don't see why I have to add more info.
Scab is the most common and damaging pecan disease. It is caused by a fungus that affects rapidly growing leaves, shoots, and nuts. Symptoms on all plant parts are similar. Velvety olive-brown to black spots occur on the husks. Several spots may develop to form black blotches or may blacken the entire surface of the husks. Severely affected nuts of susceptible varieties may drop prematurely or they may stop growing, die and remain attached to the shoot. Leaf symptoms first appear on the underside as tiny olive-brown lesions on the veins. Later, leaf symptoms appear on the upper surface as small olive-brown to black spots. Severely infected leaves may be shed prematurely and weaken the tree, thus reducing the crop next year. The most practical method of scab control is to plant varieties having some degree of resistance to scab such as: Desirable, Cape Fear, Elliott, Chickasaw, Gloria Grande, and to a lesser extent, Stuart. Varieties severely affected by scab are Schley, Mahan, Success, Van Deman, and Mohawk. Use of "resistant" varieties does not necessarily assure complete absence of the disease as no variety is totally resistant. If possible, removing and destroying all leaves and husks may help reduce the amount of scab the following year.
A spray schedule is available for growers who have spray equipment adequate to cover the trees, or for growers who hire custom spray applicators. The following fungicides are registered on pecans: benomyl (Benlate 50WP), propiconazole (Orbit 3.6EC), fenbuconazole (Enable 2F), and thiophanate methyl (Topsin-M 70WSB). Spray applications should be made every 2-3 weeks beginning when leaves first emerge until shell hardening (early August). Spray at 2-week intervals when the tree is growing rapidly or during wet periods. Check fungicide labels for restrictions on grazing in sprayed orchards and the need to use tractors with enclosed cabs while spraying.
Jul 22, 2014 | Garden
Rose diseases yellow leaves
to much sun or heat they need more shade then what you are giving them and also do not water them during the day time only water them in early morning between 7 and 8 am or at night around the time the sun is going down. watering during the day will also burn them.
May 11, 2014 | Cameras
My roses start out fine in the spring, but by mid summer they get brown spots on the leaves, These leaves soon die and drop off.what should I do?
JOKe ...... because of the brown spots .
If you really suffer from brown teeth, at best, you'd be wearing a yellow tie on
May 07, 2014 | Health & Beauty
Diseases of rose bushes
My rose bushes have what appears to be rust on the leaves.
It is still blooming and putting on new growth. But leaves are
turning yellow and falling off. I planted them this spring. I have three out of eleven effected. Not side by side.
Jan 07, 2014 | Health & Beauty
Brown spots on leaves of roses
something has been eating it
Aug 27, 2013 | Garden
I do not know when you are suppose to prune, or cut back rose bushes? I live in Florida and you never know about what kind of weather you will get. Also, what is happening when the leaves get black or...
Good luck,
Dave
Jul 16, 2011 | Televison & Video
Health & Beauty Logo
64 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
