Service manual cambridge azur 740a - Audio Players & Recorders
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
You will have to get that from Cambridge directly. Look for their website.
Posted on Jan 14, 2015
marsrover
  • 682 Answers
SOURCE: Cambridge Audio Azur 640P
best connection from pre-out to aux in.
Posted on Jul 15, 2008
fixyathing
  • 341 Answers
SOURCE: The left channel in my cambridge azur 640
have the volume control cleaned by a spray of electronic contact cleaner. If the carbon coating material is already wiped-out due to use, have the part replaced
Posted on Aug 03, 2009
Grubhead
  • 5190 Answers
SOURCE: Just set up my brand new cambridge audio azur 650a
Just make certain that the connections are all good with no wires touching. If it still doesn't perform after that return it to where you bought it and get a new replacement or your money back.
Posted on Feb 19, 2011
rajsun22
  • 73 Answers
SOURCE: cambridge azur amp 640a working
Looks like the fuse blown.. or the classic symptom of electrical fault inside the amp. 640A uses a sensitive protection circuit often ends up in this irritating situation. Normally, there is nothing much you can do, but just check your wall plug connection for Open Ground or Left & Neutral reversed issues. If the wall plug is free of error, then you should better contact CA technical support.
Posted on Mar 06, 2011
SOURCE: C/Audio Azur 640C Cd player rejects discs
Basically have a problem with this CD player design. I have one and I finally realized it was a problem of contact failure on the motherboard to the bus cable coming from the laser head. The head movement is transmitted to the connection point of making it move and fail the connection this phenomenon makes the reader is unable to read the disc. Solution, fix the bus cable head to the chassis of the mechanism of the CD just before the point of connection to the motherboard, making the movement not Transmin connector. He has not failed but for the most beatings I have given to the chassis of the reader.
Posted on Apr 03, 2011
One channel missing at switch on. Can be recovered by switch off, or A/B switch
Could be caused by a dirty or faulty switch. Perhaps even a bad soldering joint? Servisol Switch Cleaner sprayed on might cure it. Make certain you use the one that is safe on plastics.
The fact that the channel is still present is a good thing. It's just something not connecting right.
Apr 04, 2015 | Cambridge Audio Azur 740A 2Channel...
Cambridge Audio Azur 650A service manual
try:
http://www.excelia-hifi.cz/cambridge-audio/manual/cambridge-audio-azur-550a-650a.pdf
Is the user manual try the OEM for the service manual, most OEMs will require you to be qualified to do the repair.
Oct 04, 2014 | Audio Players & Recorders
I cannot open my cambridge audio 640A compact disc
This is a common issue with all belt-drive cd players, all you have to do is to change that belt and you should be done, or take it to a shop for servicing, as this is a part of a simple service maintenance routine, cheap fix though.
Nov 02, 2013 | Cambridge Audio Azur 640A Amplifier
Amplifier shows dc error and then reset
Fault at power output stage, add more information to help better.
Oct 21, 2013 | Cambridge Audio Azur 740A 2Channel...
AZUR 840E service manual
www.cambridgeaudio.com/assets/documents/tech_specs840E.pdf
Nov 16, 2011 | Cambridge Audio Azur 840E Amplifier
Whichever direction I turn the volume control knob (clock or anticlock wise), the volume always increases. I cannot turn the volume down
There's a endless volume knob who has contacts to inform if the volume increase or decrease.
It's normally produce noise and the circuit understand it like a data.
You can put a 1uF/50V capacitor in the each of 2 soldering points of the volume control to the ground (there has 3 points. One is ground and the others are live).
Best regards
Jul 24, 2011 | Cambridge Audio Azur 740A 2Channel...
Just set up my brand new cambridge audio azur 650a amplifier. It keeps cutting out with the protection light blinking three times indicating "overvoltage" according to the manual. I'm using it at...
Feb 16, 2011 | Cambridge Audio Azur 650a 2Channel...
I want to buy a trasformer for cambridge audio radio ammplifiare azur 540 v2
Cambridge Audio will be the only people that have spares
Check their website
Aug 26, 2010 | Cambridge Audio Azur 540A Amplifier
The left channel in my Cambridge Azur 640 amplifier keeps cutting out. Wierdly I can often 'shock' it back to life by quickly turning up the volume a lot. Any ideas?
Aug 03, 2009 | Cambridge Audio Azur 640A Amplifier
148 people viewed this question
 Grubhead
Grubhead
