Question about Yamaha Water Sport
Why does yamaha 60hp only go down & clicks but doesn't go up?
Water in oil in yamaha out board when old oil was drained no sign of water in oil after changing with new oil now water in oil
You need to replace all the lower seals and o-rings to the prop. I am having this done on a 2014 Mercury 60hp under warranty. Just the luck of the draw. I had a 1986 Evinrude for 6 years with no problems.
May 16, 2017 | Yamaha Motorcycles
Hi there I have a outboard Yamaha 2002 4 stroke 60hp I just want to know what's the reading psi compression Test should be thank you very much cheers
same as a car engine
150-165 psi with a variation of no more than 10% between cylinders
contact a service center and ask them for the compression pressure and how to do the test
Nov 27, 2016 | Yamaha Motorcycles
2003 60hp yamaha outboard. Water pumps fine for a few minutes, then slows and eventually stops.
Greetings
' Best deal for your solutions'. Please visit the site.
May 23, 2016 | Cars & Trucks
How do I set the carbs on a 1994 yamaha 60hp outboard?
Carefully turn airscrews in and back out 1 3/4 tuns should do the trick.
Jun 08, 2014 | Boating
Sparks from under the flywheel, causing to lose power and stall, sound like its missing
Sounds like bolts for coils have come loose,remove flywheel and inspect
Dec 19, 2013 | Boating
How do you jump start a 2007 yamaha vstar custom 650?
Sounds like the battery is dead, charge it or renew itTo jump startAs the battery is so dead remove battery leads & connect to a decent power source
Dec 29, 2011 | 2007 Yamaha V Star Custom
Water Sport Logo
19 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
