Question about NOBO S22E original lamp
How do i find out how many bulb hours are left nobo s22e
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get instructions on how to replace and swap over for a new one?
There are not even photographs of the product online...
That tells me that nobo might be using generic timers made by various manufacturers.
And they might not use the same timer one year to the next... preferring to sell whatever they can buy with lowest price.
A lot of companies re-brand generic products and sell them under their brand name, and folks assume the company made the product.. and the company has manuals... but they don't manufacture anything... they just sell stuff.
First Alert, Timex, Kingshield, Stanley, ... are examples... I suggest not buying products from companies that do not post manuals
maybe you can find a manual by doing a google image search for timers, heater timers, or Nobo ... and seeing if you can find similar timer.
Nobo timer manual below is also sold under Sunlight and Timex brands.
http://www.e-tradecounter.co.uk/PDF/p-1125.pdf
Gene
Oct 08, 2014 | Hardware & Accessories
Where do I find the instructions on how to replace the bulb in my projector please
I could not go on, because from here I have to register my projector to get support, But perhaps you can get a manual here?
Customer Support
Jun 16, 2014 | NOBO S22E original lamp
How do I find the correct instructions to enable me to change a lamp?
no need to instructions, switch of the connection of the lamp from the power source, then unscrew it, change the bulb and rescrew it back again and thats it!
How do you replace left headlight bulb?
I would say, if it is any thing like a volvo, the front bumper needs to come off and complete headlamp unit pulled out to access the bulb.
Hope I am wrong because if the dealer does it they will charge at least 1 hour labour at around $140.00 an hour. It is all a con to get the money out of your pocket and into their till
May 23, 2014 | 2012 Subaru Tribeca 3.6R Premium 4dr SUV...
Black marks on screen
my lamp problems usually start with red shades in bottom corners - red, black - same issue I think.
check your hours of filter (and clean) - clean inside your housing as helps and check lamp hours - you usually get 1500 to 3000 hours (check your user guide for lamp hours)
try and live with problem until you need new bulb as not cheap
good luck
Jan 27, 2013 | NOBO X28 original lamp
Hi, I have a NOBO heater: TYPE No. E4EU203 - 152AIX APP No. V04566 Problem - The heater has just stopped working. I have just taken the cover off and had a look at the electrinics and I have tested...
APP No. V04566
Hi - I had the same problem, rang the people I bought it from - they asked if I had disconnected it over summer - I had. Apparently you shouldn't disconnect, because battery needs to recharge - so now I have done that and it is slowly coming to life - give it half an hour or so.
Hope this is your problem - great heaters!!
Cheers
Gerda
Hope this helps
May 10, 2011 | Heating & Cooling
I have some nobo e4eu electric panel heaters with 7 day programmable timers,does anyone know where i can get programming instructions or just how to get them to work? I have tried google but nothing yet ...
The instrusctions are available in english on the australian site: http://www.nobo.com.au/Brochures/Shared/NOBO%20Timer%20Operational%20Instructions.pdf
Other useful documents available here too.
Oct 16, 2010 | Heating & Cooling
Nobo heater
the nobo heater cant keep opening for long time, i just turn it on then secound its turn off by self, i dont know if there have time contorl or not? the one im sure its not broken , just dont know how to fix this out,please help.thanks!
Feb 20, 2008 | Heating & Cooling
NOBO S22E original lamp Logo
24 people viewed this question
Top NOBO Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a NOBO Office Equipment and Supply Expert? Answer questions, earn points and help others
