Question about Canon Office Equipment & Supplies
Service mode M180 printer
How resolve error on menu of printer M180 Canon? Error code B00
    Sergeant:
  • 260 Answers
Solution: A little tricky BUT curable and saving call out labour costs.
1. stop the water supply to the dishwasher.
2. disconnect the plug from the socket.
3. you will need some slack as from the hoses on the back as you will need to pull out the dishwasher.
4. once pulled out lay the machine on its side.
5. unscrew the bottom base panel to obtain access.
6. you will see a black circular plastic box (4 cm in diameter) that one end is attached to a hose. The other end of this is visible when you normally open the door of your dishwasher and pull out the mesh 'u'shaped strainer/ filter. It sits in the hollow to the right.
7. Back to the underside! Turn the black plastic box ('box' not exactly a box but not sure what to call it!). Pull down gently at the same time.
8. No 7 is tricky and you might think that you need to disconnect the attached hose or call in a repair man. Do not despair. It just takes some gentle force to pull it out and a few swear words!
9. Once out, you will on the rim that this 'box' can be prized open. Use a flat headed screwdriver and insert into the small gaps and gently open up. Be careful as inside here is a plastic filter with a very thin membrane.
10. When I opened this up I saw that the membrane was clogged with very soft gunk. Wash this away with a rinse in water.
11. Put all back.
12. The green light may flash but just do a wash.
13. Job done.
for more help visit CBR Tech Solutions
Posted on Nov 23, 2015
jonniewalker
  • 1031 Answers
SOURCE: Canon MP830 error code 6A00
The problem apparently is related to the purge unit located at the far right side on where the printhead moves back and forth.
there appears to be three common problems that causes the error, which is related to a paper jam error. 1) If its a new printer or even an older one, there are two sponges that collect ink and two plastic wipers located in purge unit may be loose or missing. Check to see if its it there. If not, it may actually be stuck somewhere.
2) there may some paper stuck somewhere around the printhead and or the purge unit or
3) there is a build up of gooey ink on the purge unit.
, I turned off the printer & unplugged it, move the printhead to the left and used long Qtips with Windex to clean up the ink around the purge unit including a little white plastic spring-loaded lever. also dampen the sponges with Windex. If you do this be careful not to dislodge the sponge or wipers. If you do, you can alway stick the pieces back in. After cleaning it, and checking the sponges and wipers are seated correctly, plug the unit back in and hopefully it will work fine. hope this helps.dont forget to rate as fixyaa
thanks and Godbless
Posted on Oct 12, 2008
SOURCE: canon printer ix4000 service error 5C00
bagai mana caranya menanggulangi eror 5c00 Printer ix4000, mohon petunjuknya
Posted on Jun 07, 2009
Danieldesmon
  • 56 Answers
SOURCE: Canon MP190 not printing using only black ink, color ink finished
hai there...you try press the reset and colour button in the same time...the printer will back to normallyl
Posted on Mar 01, 2010
SOURCE: Canon pixma mp145 service error 5010 How to
i have error code 5010 showing?
Posted on Jul 24, 2010
alpug
  • 1961 Answers
SOURCE: I have a Canon Pixma MX320 and get the error code
Try this
1. Turn off your printer
2. Press and hold the STOP/RESET button
3. Press and hold Power ON button
4. While holding the Power ON button, release the STOP/RESET button
5. While holding still the Power ON button, press twice the STOP/RESET button
6. Release the Power ON button
7. Wait until it display an "idle" message. It will take about a minute.
8. When "idle" appear, open the top cover to expose the cartridges.
9. Lift up the cover for cartridge holder and take out both the black and color cartridges
10. Return the cover of cartridge holder and turn off the printer
11. Return the top cover and turn on the printer again
12. After the printer initialize, return the cartridges.
1. Press and Hold the STOP/RESET button and wait until it self restart.
2. Release the STOP/RESET button the the printer is restarting.
3. Wait for a few seconds
Posted on Oct 22, 2010
Error code of E-002-0000 canon printer IR 2002
Here is a link that I hope addresses the fix you need by the error if is an issue with the temperature of the fixing unit
http://www.mytechtime.com/2011/10/canon-error-e001e002-e003-e007.html
Aug 24, 2016 | Canon Office Equipment & Supplies
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
How to resolve erreur code E000051-0000 whith canon ir 2800
the Canon E500 printer is one of the most advanced printer which is build upon the latest printing technology. The printer comes in medium-size device and is reasonably light weight of around 5.3 kg. The black plastic body has no sharp edges, and the design is fairly pleasant to appear. The trays of the Canon printer Pixma E500 are quite flexible to use according to Canon Pixma E500 Printer Supportprofessionals. Its glossy finished touched feature makes the printer most eye-striking among users. But here in this blog, we will be introducing you guys with various Canon Pixma E500 error codes that you need to know.
List of top Canon Pixma error E500 codes
Error code 1: Canon E500 Error Code E02 (E,0,2)
  • This error symbolizes that printer is out of paper or is incapable of feeding any document.
Error code 2: Canon E500 Error Code E03 (E,0,3)
  • This error signifies the Paper Jam.
Error code 3: Canon E500 Error Code E04 (E,0,4)
  • The error signifies that the "fine cartridge" is not installed accurately.
Error code 4: Canon E500 Error Code E06 (E,0,6)
  • As stated by Canon Pixma E500 Printer Technical Support experts, the paper output cover is not in a closed state.
Error code 5: Canon E500 Error Code E07 (E,0,7)
  • The ink absorber is complete and users need to reset the counter.
Error code 6: Canon E500 Error Code E08 (E,0,8)
  • Here the error signifies that the ink absorber is almost in a full stage. Users are then required to press the "black or color" button to resume it in a proper.
Error code 7: Canon E500 Error Code E16 (E,1,6)
  • The ink in completely finished as of now. You are required to tap on the "Stop/Reset" button to resume the printing process.
Error code 8: Canon E500 Error Code E17 (E,1,7)
  • The front tray is totally closed.
Error code 9: Canon E500 Error Code E30 (E,3,0)
  • The error code defines that the size of the original cannot be accurately detected or even it is possible that the document is too small when the "Fit-to-Page copying" is selected.
Error code 10: Canon E500 Error Code E31 (E,3,1)
  • The machine is surely disconnected with the computer.
Error code11: Canon E500 Error Code E40 (E,4,0)
  • It shows that the protective material of the Canon Pixma E500 printer for the FINE cartridge or the tape is still attached.
Error code 12: Canon E500 Error Code E50 (E,5,0)
  • Scanning of the print-head alignment sheet has failed to function
Error code 13: Canon E500 Error Code P02 (P,0,2).
  • This is a critical error which shows that the printer is in malfunctioning stage.
Error code 14: Canon E500 Error Code P10 (P,1,0).
  • This error signifies that the mechanical printer is in total malfunction stage.
So, these are few topmost errors of Canon Pixma E500 printer that users need to be aware of. Our professional team of Canon Pixma E500 Printer Support experts is always available for you to help overcome with any kind of unexpected issues. Call us or even you may drop us an email to our professional email ID.
May 16, 2015 | Canon IR-2800 Copier Reconditioned
How to resolve problem for canon imagerunner 2420L pritner error show "restart if problem persist "
There should be an error code on the screen too, what is it? it should start with E
Sep 06, 2014 | Cannon Office Equipment & Supplies
Error Code
Hi Steve,
Please try Josh's Lab solution (on YouTube):
Josh Lab 9 Canon Printer Error 6A00 Fixed
G'Luck !
Apr 11, 2014 | Canon Office Equipment & Supplies
My canon pixma printer is showing error code 2 140 21 while scaanning???
i got this error while trying to scan. my ink cartridges were out of the printer (i was going to get them refilled). i stuck the cartridges back in and the scanner worked again.
Jan 20, 2012 | Office Equipment & Supplies
Uknown device Error - Canon PIXMA M180 All-In-One
well i'm not sure but did u try to change the usb connection itself? or if it doesnt work try to chek if there are any windows errrors but most propably the connection
Dec 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Error code 5110 Canon Pixma MP500
Error 5110 = Kann den Schlitten nicht anheben. (mechanischer Fehler)
Sep 28, 2008 | Canon Pixma MP500 All-In-One InkJet...
just unistall the usb printing support from the device driver then you you restart then you put the printer cd in the rom and try, post your comment
May 05, 2008 | Canon MP610 Photo All-In-One Printer
old marine
old marine
