Question about Paragon Spin Magic 5 Cotton Candy Machine
How to change out the voltage meter 519036 on a paragon spin magic cotton candy machine
I have a cotton candy machine and I provided it with high voltage. Higher than it supposed to handle and it just popped and its not working anymore . So whats the best thing I should do?
best thing is to junk it before some gets hurt
It is simple really , if the voltage is not what it is supposed to be then all resistors , capacitors , transistors and diodes are all affected
Feb 15, 2016 | Helman Group Nostalgia Electrics RCM605...
Took apart my machine last spring to clean after school fundraiser and storing. Pulled it out for fall carnival and plugged it in but the motor doesn't come on? Any ideas?
does it turn by hand when its off ? Sugar may have gotten into the motor shaft bearing and it tightened up . did you get it wet when you cleaned it ? that may have helped it sneak in there .
Oct 27, 2015 | Paragon 7105100 Classic Floss 5 Cotton...
Candy floss
On commercial machines there are leather floaters (tabs) that create the wind that floats the cotton candy mid bowl. If they are missing, or twisted the wrong direction the floss will fall to bottom of bowl.
Twist the leathers like an airplane propeller with the leading edge down, to force the breeze upwards. If they are twisted backwards the sugar falls and collects around the head.
Apr 27, 2014 | Kitchen Appliances - Others
Problems candy cm1146
This is not a cotton candy machine.
Nov 17, 2013 | Kitchen Appliances - Others
Why won't my cra z art cotton candy maker spin
There can be several reasons to the fault. It can be failure of the drive the motor or the drive shaft or it can related to tightness in the drive shaft shaft or bearing assembly. You need to remove and check the motor for voltage of if there is a HUM then check for resetting the drive.
Oct 15, 2013 | Washing Machines
Nostalgia electric hard candy cotton candy manual
I believe you are looking for the Manual for the Nostalgia Electrics PCM805 Hard & Sugar Free Cotton Candy Maker which can be found online here:
http://nostalgiaelectrics.com/manuals/PCM805.pdf
Jun 17, 2012 | Nostalgia Electrics Hard Candy/Sugar Free...
Machine makes loud noise when turned on to spin
I FACED THE SAME PROBLEM . BEST OPTION IS TO GO TO THE STORE FROM WHERE YOU GOT IT DONT TAKE THE RISK OF FIXING IT YOURSELF YOU MAY TURN UP COMPLICATING THE PROBLEM MORE
Feb 19, 2012 | Gold Medal Cotton Candy Machine
Hi , I recently purchased your machine and would like to know how to flavour and colour the cotton candy. I did not receive any sugar in the box , so I'm not sure what to use. Please help. P.S - Can I...
Hi pandoramagic...
This is not the company that you bought your machine from, it is an "Answer Company" we supply answers to questions people have.
You need a special sugar in the machine (read below), and you can use liquid food coloring to color the sugar/cotton candy and different liquid flavors to flavor the cotton candy.
Typical machines used to make cotton candy include a spinning head enclosing a small "sugar reserve" bowl into which a charge of granulated, colored sugar (or separate sugar and food coloring) is poured. Heaters near the rim of the head melt the sugar, which is squeezed out through tiny holes by centrifugal force. Precolored sugar packaged specially for the process is milled with melting characteristics and a crystal size optimized for the head and heated holes; granulated sugar used in baking contains fine crystals which spin out unmelted, while rock sugar crystals are too large to properly contact the heater, slowing the production of floss.
The molten sugar solidifies in the air and is caught in a larger bowl which totally surrounds the spinning head. Left to operate for a period, the cottonlike product builds up on the inside walls of the larger bowl, at which point the machine operator twirls a stick, cone, or their hands around the rim of the large catching bowl, gathering the sugar strands into portions which are served on stick or cone, or in plastic bags. As the sugar reserve bowl empties, the operator recharges it with more feedstock. The product is sensitive to humidity, and in humid summer locales, the process can be messy and sticky.
Webpage for cotton candy supplies: http://www.epopcorn.com/cotton-candy-machines-cotton-candy-supplies.html
Please take time to rate me
Aug 31, 2011 | Helman Group Nostalgia Electrics RCM605...
Paragon Spin Magic 5 Cotton Candy Machine Logo
Top Paragon Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Paragon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
