Question about Sentry Fireproof Safe
Combination lock will not work. i took it apart .
Combination lock on my safe dont work like it should. i took the lock apart and put it back together again the numbers doesnt work well. im trying hard to find some help so i hope u can me.
My combination parts are:
Flat Dial Parts List: 1.insert.2.dail,3.spindle(shaft),4.attaching screw(mounting screw),5.dail ring,6.spacer washer,7.compression spring,8.1st wheel,9.2nd wheel,10.3rd wheel,11.4th wheel (drive cam),12.quarter pin. these are the part of the truning lock to open and close. hope u can help . if not send me to someon u may know. thanks for ur time.
  • 667 Answers
SOURCE: Sentry 1610
Hmm, Those coin sized cells are fairly common as to types used. CR-2016, CR-2025, and CR-2032 would be my guess...
Posted on Mar 28, 2008
SOURCE: sentry safe
**** seyntry safes....piece of **** has all my important documents stuck in it.
Posted on May 19, 2008
  • 33 Answers
Yes I agree. Their key lockable products are much much better.
Posted on Feb 16, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
SOURCE: hi i locked my combination papers to my brinks
Posted on Jan 03, 2010
Pfaff 1212-115- how to put the hand wheel back together. I took it apart because it Seemed to be locked. I engaged and disengaged it several times. Didn't work
these machines have powerful motors and they can be super dangerous if not re-assembled correctly, and more damage can result on top of that. There are lots of honest sewing machine stores with qualified personnel to take care of your sewing machine repairs safely.
Embroidery Services
San Diego, CA
Nov 22, 2016 | PfaFF Sewing Machines
"How do I put this back together Door lock latch diagrams"
does it look anything like this , sorry hav'nt got the item list , get a workshop manual if this is not helpful , keep me posted if you wish
Jun 02, 2014 | 2001 Chrysler PT Cruiser
My wireless controller was dropped and when i went to use it the L1 button would not work when pressed, so i took it apart then put it back together and now the L1, L2, R1, and R2 buttons dont work when...
Something happened when you took it apart. Either you dropped a piece, or the pieces are not lining up properly. Take the controller apart again and double check to make sure that everything will touch the contact points they are supposed to touch as you put it back together again. If it still doesn't work, then you might have accedentally damaged a lead on the little circuit board inside it, and at that point you will probably have to buy a new controller.
Aug 12, 2010 | Sony Wireless Controller for PS3
DE shows-the door will not lock.I even took it apart.
door lock is not designed as a repairable item.just buy a new one.if it still dosent work,give the door an additional push.if it still dosent go ,brobably a fault with the main power board.(rare)
Feb 02, 2009 | LG WM-2277HW Front Load Washer
Having trouble putting door together
Whenyou took the door apart did you take note of how so you can reverse the proceedure Sorry it is difficult to explane in words on how to put a door together all I can say is try placeing the panels from the top down and bottom up then if anything works put in all the screws halfway then after all the screws are in then tighten them as evenly as possible
Jan 22, 2009 | GE Nautilus 24" Built-in Dishwasher
Door locks wont unlock or lock
The electric door actuators are bad/broken so they need to be replaced its a common problem
Dec 14, 2008 | 2005 Ford F-150
Cant get it back together
I put together what I knew where it went, the put the whole thing together and looked at it before putting in the screws. I saw a hole and remembered a "button" there that moved sideways with a spring pushing it back into the original place. I reopened and after examining the part put it in that slot. I then put it together and it worked. I put the screws back in then and all is well
Thank you for the reply.
Glad I found your site. I will keep it if I ever need any help.
Oct 11, 2008 | HP Wireless Optical Mouse
Car door lock replacement
Go on YouTube and input your vehicle information.
Nov 02, 2017 | 2001 Mitsubishi Montero Sport 4WD
Sentry Fireproof Safe Logo
175 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Hannah Johnson
Level 1 Expert
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
