Question about Acer V173 b Monitor
WHEN OPENING A PROGRAM THE MONITOR BRIEFLY TURNS BLACK
Dell dimension 4700 pc monitor screen turns black
You might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs.
Jun 23, 2012 | Dell Dimension 4700 PC Desktop
BenQ Q22W6 How to open the case?
The fact that keyboard action causes it to display briefly would be an INDICATION that there is no problem in the monitor but a software problem. I suspect you may have a virus or some other problem with the driver for the video. Search google for: VIRUS DISPLAY PROBLEM and you may find a virus name that is causing this... there have been several... You will have to use another machine to search of course since yours doesn't display. You probably have been infected with one of the MALWARE type virus. The virus prevents you from searching to find a solution.
May 25, 2012 | Computers & Internet
When computer off monitor displays orange light.when i turn computer on green light briefly on than goes out. Monitor remains black'
This is not always a problem with the monitor. It could also be caused by a faulty display card in your computer. Try plugging your monitor into a working computer to determine where the problem lies.
Best wishes,
Graemevm
Jun 08, 2010 | Computers & Internet
1905FP Monitor Powers up, briefly shows logo, blacks out.
Look inside for bad caps with bulgng tops, worst case will be shorted out transistors in the backlight inverter circuits or bad lamps. Check to see if you do have he 12vdc for the inveter circuits. See example of failed monitors with bad caps here: http://s807.photobucket.com/home/budm/allalbums
Jan 12, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
Samsung Sync Master 943bw monitor shuts down after a few minutes, behaves as though it is overheating, will only flash briefly if attempted to open immediately. starts again after standing for some...
Mine shut down during my normal working day. Same thing, turn it off and on again - screen flashes up briefly then flicks off again.
Called Samsung and they are replacing it with a refurbished screen under warranty.
Dec 08, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
I turn my monitor on and I see the display breifly
hi. it sounds like the power supply has gone bad... try to purchase a new power supply cord..
thank u
rate me
Jul 19, 2009 | ViewSonic VX800 18" Flat Panel LCD Monitor
Monitor Screen goes black seconds after turn on-
I ended up fixing my problem, but I'm not sure what the solution is. I had some faulty electrical equipment that I was using to power the monitor (220V to 110V converter and a bad power strip) and I got rid of them. I was using the converter because I moved to Israel and I thought I needed to feed the monitor only 110V, but I now realize that the power cord for the monitor has a built-in converter that accepts 220V input. Now the monitor is plugged directly into the wall and is working fine. Try using a different power source (maybe the wiring or plug you're using is faulty). Good Luck!
Apr 21, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
VGA input not displaying
Hi, insert the monitor driver of screen on swicth reinstall driver in order to detect screen.
Jan 17, 2008 | Samsung SyncMaster 713BM 17" LCD Monitor
Acer V173 b Monitor Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
