Question about "Buffalo Dental Manufacturing Co.," Tools & Hardware - Others
******** plugged iun but not powering on - "Buffalo Dental Manufacturing Co.," Tools & Hardware - Others
T.V. wont come on although the red lite is on when plugged iun and the blue lite comes on when you hit the power button the screen does nothing it is a haier 32 inch LCD model L32F1120
Hi Judy
How old is your unit? but any way the problem of your unit is probably leaky capacitor. kindly check on the internet how leaky capacitor looks like.
Jan 19, 2014 | Televison & Video
I get my battery charged the car will run but act as iun
Check the acid level or check whether the battery terminals are connected correctly.
Aug 07, 2012 | 2002 Saturn L-Series
My computer will no longer recognize my camera when I plug it in.
Check in CTRL Panel SYSTEM Device Manager HARDWARE and delete the reference to the power shot.
Also you can try uninstalling it and then reboot and installing it again.
USB plugs can be a nuisance sometimes by chganging the port to suit whatever new installtion of a usb device wants to use. I have had this happen several times with my canon.
I can alter the port numbers But i am reluctant to tell you what is involvd iun case it causes you more grief than what you already have. just follow my basic suggestions and it should help to get it back. Do not have the camera connected when you reinstall it. Let it be rediscovered after installation, when you connect it WEindows will then load all the drivers and set the port for you.
Please rate my help++++Thanks for using FIXYA
May 07, 2010 | Canon PowerShot A580 Digital Camera
How i can download games and programs in ipod touch 8G?
create an iunes accouny go to appstore from your itouch thats it or use itunes on your pc goto itunes store and download whatever you want
Jan 16, 2010 | Apple iPod touch
Need guide/manual for Plantronics 222 Blue Tooth
first question,i have anplantronics explorer 242 when i plug it iun to charge it the light ired then after a few min. it turns blue,how do i know when its fully charged? will the lights go off?
Dec 16, 2008 | Plantronics - Bluetooth Headset Plus Base...
Car audio
You need to use a multimeter to see if the remote turn-on voltage at the amplifier is dropping to near 0v as soon as you switch off the head unit. If it's not, you need to determine why it's not switching off quickly.
Dec 28, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Feeder problem
posibilities r ink,rollers,catridge head etc so loos n check these things if there iun place
Dec 04, 2007 | HP Officejet 5510 All-In-One Thermal...
Cable plug-iun
unless you are good with a solder iron & can recognize were the center pin of the coaxial went you will need to take that to a shop, even then there is a possibility that you have damaged the board inside the tuner & may need a replacement
Apr 02, 2007 | RCA HD56W58 56" TV
Now i blow the outlet fuse insted of the tv fuse
Take me back to the original symptom and how you determined to change the HV block----For now,have you put the original back
and the mfr correct rated fuse(s)?? Have you double-checked
that the transformer lead is in correct flute in HV block??If not,
you likely will blow something!  Let me know....T.
Jan 17, 2007 | Samsung PCJ534RF 53" Rear Projection...
Tools & Hardware - Others Logo
35 people viewed this question
Top "Buffalo Dental Manufacturing Co.," Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a "Buffalo Dental Manufacturing Co.," Tool and Hardware - Other Expert? Answer questions, earn points and help others
