Question about Manhattan Barcode scanner contact USB Barcode Scanner
Sg303 high performance ccd skaner - Manhattan Barcode scanner contact USB Barcode Scanner
Where to buy a new CCD for Kyocera SL400R? What is the part number of this blessed CCD ?
You could try Kyocera, but I don't think they still have 10 year old CCD's in stock. And if they have, it could be more expensive then a brand new DSLR. And even if you have a CCD, who will replace it and what reassurance do you have nothing else is defect in the camera.
After 10 years perhaps you should try to accept the camera is beyond repair and new camera's now perform better and faster, for less money.
Jan 08, 2015 | Kyocera Finecam SL400R Digital Camera
Skaner will not skan
You did not specify make or model, but here are a few likely causes:
1 - SQUELCH is turned down too low, and background static is keeping it from scanning, as it "thinks" it has a station.
2- You channel memory may have been wiped out (Unplugged too long, old backup battery, etc) and lost its settings. Check that by manually scanning to a few freq's and see if it works. If it does, come on back here and post the result, and we'll try to find a solution for you.
Nov 14, 2014 | Radio Communications
Need barcode list for SG303
if you don't have the device application software download it from your cd driver that come with your device and locate the setting of the scanner in the configuration area you will find where you can initialization
Jan 14, 2014 | Manhattan Computers & Internet
Where could I find a list of Fault Codes for my 3.3 Litre Voyager?
CHRYSLER OBDII DTC
P1101 HCM/PCM Communication Performance
P1103 Turbocharger Waste Gate Actuator Malfunction
P1104 Turbocharger Waste Gate Solenoid Malfunction
P1105 Fuel Pressure Solenoid Malfunction
P1195 Slow Switching O2 Sensor Bank One Sensor One During catalyst monitoring
P1196 Slow Switching O2 Sensor Bank two Sensor one During catalyst monitoring
P1197 Slow Switching O2 Sensor Bank One Sensor two During catalyst monitoring
P1198 Radiator Temperature Sensor Input voltage too high
P1199 Radiator Temperature Sensor Input voltage too low
P1281 Engine is cold too long
P1282 Fuel Pump Relay control circuit
P1283 Idle select signal invalid
P1284 Fuel Injection pump battery voltage sensor out of range
P1285 Fuel Injection pump controller always on
P1286 Accelerator Position Sensor (APPS) supply voltage too high
P1287 Fuel Injection pump Controller Supply voltage low
P1288 Intake manifold short runner tuning valve solenoid circuit
P1289 Manifold tune valve solenoid circuit
P1290 CNG Fuel system pressure too high
P1291 No Temp rise seen from intake heaters
P1292 CNG Pressure sensor voltage too high
P1293 CNG Pressure sensor voltage too low
P1294 Target idle not reached
P1295 No 5 volts to TP sensor
P1296 No 5 volts to MAP sensor
P1297 No change in MAP sensor from start to run
P1298 lean operation at wide open throttle
P1299 Vacuum Leak detected (IAC fully seated)
P1300 Ignition timing adjustment circuit failure
P1388 Auto shutdown relay control circuit
P1389 No ASD relay output voltage at PCM
P1390 Timing belt skipped one tooth or more
P1391 Intermittent loss of CMP or CKP
P1398 Mis-Fire Adaptive Numerator at Limit (PCM is unable to learn the crank sensors signal
for use in preparation for misfire diagnostics
P1399 Wait to start lamp circuit
P1403 No 5 volt feed to EGR
P1475 Auxiliary 5 volt supply is too high
P1476 Too little secondary air
P1477 Too much secondary air
P1478 Battery Temp Sensor Volts out of limit
P1479 Transmission Fan Relay Circuit
P1480 PCV Solenoid Circuit
P1481 EATX (Electronic Automatic Transaxle) RPM pulse generator performance
P1482 Catalyst Temperature Sensor Circuit shorted low
P1483 Catalyst Temperature Sensor Circuit shorted high
P1484 Catalytic Converter overheat detected
P1485 Air injection solenoid circuit
P1486 EVAP Leak Monitor found a pinched hose
P1487 Hi Speed Fan #2 Circuit
P1488 Auxiliary 5 volt supply output is too low
P1489 High speed fan control relay circuit
P1490 Low speed fan control relay circuit
P1491 Radiator fan relay control circuit
P1492 Ambient/ Battery Temp sensor input voltage too high
P1493 Ambient/ Battery Temp sensor input voltage too low
P1494 Leak detection pump pressure switch or mechanical fault
P1495 Leak detection pump solenoid circuit
P1496 5 volt supply, output too low
P1498 High speed radiator fan ground control relay circuit
P1500 General alternator 'FR' Terminal circuit fault
P1594 Charging system voltage too high
P1595 Speed control solenoid circuits
P1596 Speed control switch always high
P1597 Speed control switch always low
P1598 A/C pressure sensor input voltage too high
P1599 A/C pressure sensor input voltage too low
P1680 Clutch released switch circuit
P1681 No I/P Cluster CCD/ J1850 messages received
P1682 Charging system voltage too low
P1683 Speed control servo power control circuit
P1684 The battery has been disconnected within the last 50 starts
P1685 The SKIM (Smart Key Immobilizer Module) has received an invalid key
P1686 No SKIM (Smart Key Immobilizer Module) bus message received
P1687 No Mechanical Instrument cluster bus message
P1688 Internal Fuel injection pump controller failure
P1689 No communication between the ECM and injection pump module
P1690 Fuel injection pump CKP sensor does not agree with the ECM CKP sensor
P1691 Fuel injection pump controller calibration error
P1692 Fault in companion Engine control module
P1693 A companion DTC was set in both the ECM and PCM
P1694 No CCD message from PCM- Aisin transmission
P1695 No CCD message from body control module
P1696 PCM failure EEPROM write denied
P1697 PCM Failure SRI (Service Reminder Indicator) mileage not stored
P1698 No CCD message from TCM
P1719 Skip shift solenoid circuit
P1740 TCC solenoid or overdrive solenoid performance
P1756 Governor pressure not equal to target at 15-20 psi
P1757 Governor pressure is above 3 PSI when 0 PSI is requested
P1762 Governor pressure sensor offset improper voltage
P1763 Governor pressure sensor voltage to high
P1764 Governor pressure sensor voltage to low
P1765 Transmission 12 volt supply relay control circuit
Oct 03, 2010 | 1998 Plymouth Voyager
THE PICTURE TAKEN WITH FLASH IS ALWAYS MORE ON PINK COLOR
This is imbalance of the white balance of the camera. If there is no fault with outdoor shots then the CCD does not compensate the high intensity flash specially when bounced closer.
Set the camera manually to outdoor high brightness and test.
If the pink seems to come back irrespecitve of any of the settings the CCD circuitry is faulty.
Sep 17, 2010 | Samsung Digimax S700 Digital Camera
Haw to reset gestetner2722ztd error E1
press dot ( . ) on the left side of 0 so we could know whats the second defree number is. to reset press energy saver once then 107 press stop button until 1 blinks then 5 # 810 # turn off copier then on.
Jan 10, 2010 | Gestetner Copier
Canon imagerunner 400 service manual guide for errors
Canon400
Code Descrihtion
E0 Fuser
E1 Sorter
E2 Skaner home
E3 Scaner
E4 Clock pulse or open RF door
E5 Lens position
E6 Exposure lamp, fuse 2
E8 Counter
Jul 18, 2009 | Canon Office Equipment & Supplies
Manhattan Barcode scanner contact USB Barcode Scanner Logo
73 people viewed this question
Top Manhattan Computers & Internet Experts
Gareth Cockram
Gareth Cockram
kamal dev  jhalli
kamal dev jhalli
Are you a Manhattan Computer and Internet Expert? Answer questions, earn points and help others
