Question about Robinair 34788
Our model 34788 a/c machine wont let us add oil to the system, what can be wrong?
How to oil the singer 776 swing machine
Singer sewing machine controls - YouTube
? 3:37
https://www.youtube.com/watch?v=yO3OlJXSoMQ
Jun 26, 2012 - Uploaded by cindylouwho0619
1:54. How To Clean and Oil A Sewing Machine - Duration: 12:07. by Niler Taylor 245,750 views. 12:07. How ...
Winding a Singer Sewing Machine Bobbin - YouT
Dec 09, 2015 | SewShop.com Singer Model 776 Instruction...
We have a robinair 34788 and it wont recover
Does it flash any codes on the screen when you attempt to recover? You'll want to check the inline filter as well as the condition of the pump oil.
Aug 03, 2015 | Robinair 34788
The switch on my machin will not go on what do i do their or whats wrong with that what do i do to fix it?I plug in the rug doctor then i flip the switch but it wont go on.
bad switch or broken wire in the cord . use a continuity tester to check from the plug to the switch. if the cord is good check the switch itself good luck
Apr 27, 2015 | Rug Doctor 95730 MP-C2D Mighty Pro Carpet...
Which kind of oil using for SV 520T sammic vacuum machine
Here is the link to the owner's manual for your model. It tells you everything you need to know about adding & changing the oil and what oil to use:
http://www.sammic.com/dl/116722/a1f67/instructions-vaacum-packing-machines-sv-t-timer-w-vac-norm-new.pdf
Feb 03, 2015 | Vacuums
It smells like it's burning when I vacum/what's wrong with it
Tammy May:
Unplug the machine and remove the foot plate (at the bottom of the vacuum head) and check the belt that drives the beater brush/bar. if the beater bar is hard to turn, pull the beater bar and belt out, check the inside circumference of the belt to see if the motor shaft has worn it down in one spot. If so, remove the two bearings (one at each end of the beater bar) and remove the hair, carpet fibers, strings and any other junk from the bearings and the ends of the beater bar. lubricate the bearings with oil (thin machine oil like 3 in 1 oil works best. roll the bearings with your hands until they spin freely. Now would be a good time to check the bottom of the foot plate where the dirt is vacuumed up. check the hole in the middle of the foot plate and check the hose for clogs if the hole and foot plate hole are clear, reassemble the bearings on the beater bar and install the beater bar (with a new belt) and reinstall the foot plate. The machine should run well for you.
Jan 19, 2013 | Eureka Vacuums
My Beaumark popcorn maker isn't working! I have the type that is a large domed electric pan, with a metal 'stick' that goes around to move the kernels (presumably to stop them from sticking?)....
your problem is in the instructions.. you need to make it a little hot, means run it on empty for a few min. stop the machine, and add 2 tablespoosn of veg. oil your fav. oil, not olive. add enough pop corn to fill the inner circle surface of the bottem plate, then run it again until the bowl is full.. maybe 5 min. You should have perfect bowl full of pop corn.
enjoy :-)
Sep 15, 2011 | Vacuums
I got a FREE old but lightly used Oreck XL 8300 xtended life commercial. 120V 60 Hz. After cleaning brush etc. is there anywhere to add oil to the electric motor? Is it necessary? Is this machine worth the...
I don't believe that the bearings have a place to oil them. As for the machine being worth the time, I think yes. Orecks are used extensively by hotels, and are noted for their reliability, longevity and weight.
Best regards, --W/D--
Feb 19, 2011 | Oreck Vacuums
My machine wont sew properly I broke the needle awhile ago and now it wont sew propery was hoping a manual would tell me what is wrong
Your possbly out of time ,meaning the machine isnt in synch after such a big event. check the website for putting back in time otherwise ,disconnect it off the drive and try and put it whare it needs to be
Feb 15, 2011 | Vacuums
I was vacuuming then all of a sudden the vac turned off and wont go back on. i thought the bag might be full so i emptied it and still it wont go back on
Greetings from GoVacuum.com,
There maybe several things wrong with the vacuum at this point. When a vacuum cleaner doesn't turn on, it usually is 1 of several things. It's either a reset button on the machine, the cord, the plug, the switch or the motor. One of these things have gone bad in your machine.
If you'd be so kind as to let me know your make and model, I can help you diagnosis the vacuum to find out what went bad.
Please email me your make and model to chris.jones@govacuum.com
Chris Jones
GoVacuum.com
Oct 15, 2008 | Vacuums
Suction
your machine has a clear plastic front cover. its on wrong.
if it has an inner crescent shaped one it may be that one.. the fact it catches on the ground... guaranteed.. and yes i used to answer the phone for bissel in this regard.. hell call em the number is on the model # tag..
Jun 04, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Robinair 34788 Logo
41 people viewed this question
Top Robinair Vacuums Experts
Are you a Robinair Vacuum Expert? Answer questions, earn points and help others
