Question about WYSE Winterm S30 Network Terminal
Wyse wuterm v50
Bios password
Bios password
You Will Need to Completely Disconnect Computer From Power, All batteries Including motherboard battery ext. For 6-7 days. Always Seems to work for me. Will Need to reinstll windows
Nov 25, 2013 | WYSE X90L Laptop
USB port on Wyse VX0 is not enabled. How do I access control panel to manage settings?
You have to enable it in BIOS. Look up how to get to BIOS on your particular computer. (Make & model)
Oct 24, 2013 | WYSE Winterm V90LE Thin Client - Thin...
Wyse S30 power settings
You can check the settings in the bios (password will be "Fireport") I dont think there is anything in there that would trigger this.
Is there a screen-saver option in the control panel for the device? If so, see if it is set. If not, then try using the Wyse website to update the terminals OS to the latest. This will hopefully solve the problem. It might just be an incompatability with the older OS version.
Jun 22, 2009 | WYSE Winterm S30 Network Terminal
WYSE S10 thin clients; we are hearing from users that when they hit the power button, the unit restarts instead. This behavior is also present using the gui interface. Not all units are doing this, but we...
Check in the BIOS, "Fireport" is the password. I cant remember if the power button behavior is set there or in the wnos.ini file.
You can check the config generator on technicalhelp.de to see if the command is in there for the wnos.ini
Apr 07, 2009 | WYSE S10 (90210501) Network Terminal
How can i reset the bios password of my wyse vx0 machine?
wyse model no vx0 bios pssward remove videos
Jan 09, 2009 | Computers & Internet
Bios password
You should be able to re set passwords in the bios by putting jumper on JBAT 1 terminal from pins 1&2 to pins 2&3 for a few seconds then back to pins 1&2, but you will have to set the time again etc.. But you may also find there is also a network log on password which is another story. Your Ratings are important
Nov 13, 2006 | WYSE Winterm 3320SE Network Terminal
WYSE Winterm S30 Network Terminal Logo
83 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
