Question about ASUS M2A-VM Motherboard
Bios cmos check sum error - ASUS M2A-VM Motherboard
    Top Expert:
  • ASUS Master
  • 10,875 Answers
Update bios
Posted on Apr 07, 2015
    Brigadier General:
  • ASUS Master
  • 3,400 Answers
CLEAR CMOS.
  • 70 Answers
Replace your cmos battery.
Posted on Apr 05, 2015
2 Suggested Answers
  • 140 Answers
SOURCE: on starting my pc error
Check your system USB connector having any short circuit, you can test it by removing all USB connections. Then again it showing USB over current error it is related to your Motherboard ICH problem, motherboard to be replaced
Posted on Sep 25, 2010
Bios check sum error
replace ur cmos battery
May 07, 2014 | ASUS Computers & Internet
Error code reads "Cmos Check sum error-default
You need to fit a new bios battery a cr2032 normally
My tech team and I can help lots with PC stuff it would begreat if you could ask any PC questions you have here so we can guide youthrough it and discuss it properly http://www.mypcmates.com
Nov 05, 2010 | Biostar GEFORCE 6100-M9 Motherboard
I have gigabyte gl 81915 motherboard on my cabinet. but some days ago it's display check sum error default loaded so how can i solve it give me solution?
The CMOS checksum error occurs when the CMOS battery is worn out and the CMOS data gets corrupted. Replace the CMOS battery, this battery most likely a CR2032 lithium coin size button battery - check to make sure before you purchase.
After replacing with a new battery, then go to the BIOS configuration and set the Time
Sep 02, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
I have problem with this board when i open it there a message bios check sum error, i need to insert system disk but i don't have it
You can clear the cmos by removing the lithium coin battery, and short circuit the contacts in the batter holder, then re-insert the battery. That will set the cmos settings back to factory default.
Feb 21, 2010 | Intel D101GGC Motherboard
Reset BIOS on HP Pavilion a750w
Fastest way to reset BIOS is to remove the CMOS battery (looks like a large watch battery on Motherboard) for 30 minutes. After you replace the battery, the BIOS should reset to default. If further problems arise involving the BIOS, it's possible the CMOS battery is bad.
Dec 13, 2009 | HP Pavilion a705w PC Desktop
COMPUTER CHECK SUM ERROR'S ?
if you can enter bios (usually by pressing f2 or del), then load the default settings, otherwise, you will have to position the jumper properly, instructions for that are as follows.
1. Touch an exposed metal part of the case to ground yourself.
2. Unplug the power supply from the wall.
3. Move CMOS reset pins to short pins 2 and 3, then wait 10 minutes.
4. Replace CMOS reset pins back to 1 and 2.
5. Replug the power supply and boot.
Jan 20, 2009 | Acer Aspire™ T180 PC Desktop
Usb cdrom not supported
First of all confirm that all system are of the same make and all this contain same motherboard.
1> Next if all have the same mother board than check for the cmos setting in the peripherals option and look for the usb support drives is enable or not.
So there is setting the cmos only and if this bios is not update than find for update bios from the mother board site. and try upgrading the bios and please take precaution that during the bios update process system must be on ups so that power failure not occur other wise bios will be dead.
Jan 16, 2009 | Acer Aspire™ T180 PC Desktop
I am getting 1 long beep and then 6 short ones
Hi canturob,
When a system reports a check sum error the bios is telling you the information stored from the last working boot does not match the current settings stored in the bios. Please power down your MSI system, unplug the power cord. Open the case & clear the bios. Location of JBAT1 on page 3 in manual.
Clear CMOS Jumper: JBAT1 page 10 in the manual. Remove the battery/cmos. Check it's voltage with a volt meter. It should test to 3volts DC. Anything less & the battery needs to be replaced.
While in the case re-check all data cables & power cables for good connection.
The MSI board uses the Award bios. Your current beep code of 1 long & six short is not a common beep code for the Award bios. See bios beep codes here: http://www.bioscentral.com/beepcodes/awardbeep.htm
If the battery checks out ok, you may need to update the bios. Go to MSI: http://global.msi.com.tw/index.php?func=downloaddetail&type=utility&maincat_no=1&prod_no=205
To update your MSI bios (Option only if bios clear fails to resolves the check sum issue).
Good luck canturob!
Mike
Dec 03, 2008 | MSI PM8M-V Motherboard
Check sum error denioted in win xp
you internal cmos battery is flat needs replacing. then reset time and etc in bios
Oct 10, 2008 | Televison & Video
Press F4
svjyrat
"always message to press F4 at the time of star up". this problem happen when CMOS detect any error. is also happen if CMOS battery fail (Chack sum error).
to solve this problem at first check CMOS battery (it voltage less then 3V or not) if it bad then replace it. u can buy this battery form any computer accessories shope.
or if u not connect floppy drive, and controller enable. if u desable floppy drive contoller from CMOS setup (in intel mother board is show BIOS setup) then this problem solved.
Jul 03, 2008 | Intel Motherboard
ASUS M2A-VM Motherboard Logo
98 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
