Question about Jandy Pool & Spa
Godiva fire pump gmb2700 - Jandy Pool & Spa
I put a new fuel pump in rear tank and fuel filter but not starting.im getting fire at fuel pump but no fire from relay .i put new relay still nothing
Fuel pump will usually only run when on Crank. When engine fires up then it stays running. This is so it won't pump in a crash.
Jan 31, 2015 | Cars & Trucks
Engine firing order
If the leads or not correct for the firing order you will have a pronounced miss/ back fire or hard to start. If the fuse to the fuel pump keeps blowing then the pump is shorting out or is drawing too much current in it's operation. Acceleration will demand a plentiful supply of fuel and if the pump is having problems replace the pump . have the fault codes read and have a fuel pressure test done on the fuel manifold to check -filter and fuel regulator operation
Nov 21, 2013 | Cars & Trucks
Where is the fuel pump relay on a 94 prizm
alldata.com
it is all there.
pumps do not get fire. nor spark.
they get 12vdc . (no fire there unless a dead short, and no fuse)
Dec 27, 2012 | 1994 Geo Prizm
1996 Toyota Windom no fuel no fire
dose the fuel pump come on when you turn the key on listen for the fuel pump to come on
Jun 12, 2012 | Cars & Trucks
Fuel pump not working on starting my picup
FUEL PUMP CIRCUIT IS CONNECT TO IGNITION CIRCUIT. MALFUNCTIONING MOD. (NO OR INTERMITTENT ) PLUG FIRING.
ANTI BACK FIRING FEATURE TO STOP ENGINE FIRES.
May 02, 2012 | Cars & Trucks
Turns over and won't start, replaced fuel filter and just turns over and almost fires
Almost fires? Do you mean it does fire some, that you know the plugs are getting spark? If so, then you probably need to have your fuel pressure tested to see if pump is working properly. Can you hear the pump buzz on briefly when you turn key to on? It should come on for a couple of seconds to pressurize the lines. If you don't hear it, then your pump may be bad, or something not turning pump on. Good luck.
Nov 09, 2011 | 1995 Buick Regal
Will tiurn over but will not start
make sure the engine is firing,if engine not firing bad crank sensor..... if engine is firing, it could be fuel pump relays,bad connection at fuel pump if fuel pump on the frame, or fuel pump itself
Jan 19, 2011 | 1989 Ford F 150
I just replaced the batteries in my TI 83 Plus and
Hello Lady Godiva,
You may try to visit the Texas Instruments FAQ and Knowledge Base to read the article that addresses your question. The article has links to additional troubleshooting.
Hope it helps.
P.S. You may not know it but the name given to a model of a bare nuclear reactor happens to be Godiva, in honnor of the historical Lady Godiva., the wife of a less famous German Burgmeister.
Nov 02, 2009 | Texas Instruments TI-83 Plus Calculator
No power to fuel pump, relay is good, engine cranks over but won't start.
You need to follow a detailed troubleshooting procedure in a repair manual.
Check for spark plug fire during cranking after it dies.
No spark = ignition problem= computer will not fire injectors, and possibly cut out pump also.
Good spark = pump wonky, or power to pump system.
Also, other quick tests... when the thing dies, and then you crank,
1) Thump the fuel pump in the tank, if you can. A bad fuel pump might start up again.
2) Shoot some ether carb cleaner in the TB. If it only fires off the ether, the ignition system is no longer suspect.
Oct 13, 2008 | 1992 Dodge Dakota
Pool & Spa Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
