Question about Karcher Vacuums
Why is Hoover not sucking - Karcher Vacuums
Help! My boyfriend took apart my hoover platinum carpet cleaner
That sucks! Um, if you do not have the manual, here it is
http://hoover.com/file/622/
If that does not help. you can contact Hoover
https://hoover.com/contact/
Flick the boyfriend
May 08, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Well the hoover seems to be sucking in very poorly and nothing off the floor is being sucked up. how can i make it stronger suction?
u need to make sure that the dust collector is empty and any filters fitted are clean and check the hoover belt if fitted is working
Feb 19, 2010 | Vacuums
Blowing insteading of sucking
Go online to HOOVER.com and locate your nearest repair facility. Take receipt with you to show it's a new purchase.
Feb 05, 2010 | Vacuums
Not Sucking!
If you have the instruction manual check for how your vac breaks apart. It sounds like you may have to follow and break away all parts until you find the blockage. I am assuming you have full power in your motor .
Aug 23, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover doesn't suck well
Did you check the inlet from the bottom? Take the bottom plate off, make sure that the tube(inlet)is free of any clogs. Also if the belt is stretched, then it won't drive the brush roll like it should, replace it part #38528033.
Feb 04, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Vacuums Logo
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
