Question about Garden
Ignition on H3011 honda riding mower won't turn off
Ignition on Honda 3011 riding mower won't turn off
  • 124 Answers
SOURCE: i have a Honda 2216 ride on mower when hot it
Most likely this is a valve problem caused by a carbon build up around the valves. This is not a job for the novice due to it being an overhead valve engine. Poor quality gasoline can cause this problem. I recommend that you always use white gas if it is available in your area. If it is not available try to find the gasoline that has the lightest yellow color. The darker the yellow color the more sticky varnish deposit that will be left behind. And totally avoid gasoline that has a orange color. The darker the color the more problems it will cause.
Posted on Sep 13, 2009
SOURCE: i i have a honda htr3009 riding lawn mower that
Don't forget the interlock cutouts that kill the engine (by turning off the ignition) if (a) there is noone on the seat when the PTO is on or a gear is engaged
Posted on Jun 22, 2010
  • 3074 Answers
SOURCE: I have a 16hp Honda
just trying to grasp the situation here: I am assuming that it will not fire means it is cranking but not starting.... pull the plugs and have them laying where you can see if they are sparking, if they are then the coil is good, this means that the gas is not getting to the plugs, you will need to disconnect the gas line on the fuel filter, gas should come out of the hose, if not then the line or the bottom of the tank is clogged, if it does then hook it back up and disconnect the line after the filter, check for gas, if none the filter is clogged, if yes then disconnect the gas line from the carburetor, same as before. Hope this helps Tim if the situation is different then post and if I am still here I will answer
Posted on Apr 17, 2011
kel1guy2002
  • 3740 Answers
SOURCE: honda ride on mower 2216 when
Hi and welcome to FixYa, I am Kelly. I looked up the Model HF2216 via US Honda power sites and did not come up with a manual. If you would state your geographic (not home address) location and the engine number off of the engine. U know this is a V-twin but not sure of the Hp rating and need the engine number for service manaul data.
What your describing sounds like an automatic choke that needs adjusted. Pass me the engine number and I will get you the data.
Thanks,
Kelly
Posted on Jun 19, 2011
SOURCE: john sabre ride on mower
I have had similiar problem with the Sabre machine. On mine if the parking brake is set, and seat safety is closed and you pull down the blade engagement slightly further then the disengaged position the key will work. The only problem i continuously have even after replacing the battery is the low amperage cranking on ccold start...once warmed up starts no problem without the boost. I wonder if these machines typically have either a resistor built into the key switch which limits too much cranking power or if its something to do with the crank being sealed so tight as i also find it cranks over alot easier with the oil cap loosened up...just dont forget to tighten after starting!
Posted on May 30, 2012
How do I release a jammed starter motor on a Honda 1211 Hyrdrostatic Ride On mower?
Pull the spark plug and try again many times the fuel get into the cylinder and will not let motor turn over . if it goes change the oil also and put a shutoff valve in the fuel line
Mar 30, 2015 | Garden
Where is the cut off sensor for honda ride on mower
Theres more then one theres probably three to five one for blade one for brake one for backup one for seat take your pick they all run off the one wire that comes from your ignition coil .If you just want to see if its the switchs take off cover of engine and pull the small wire off the coil that will bypass all the switches .Its a start
May 08, 2014 | Honda Garden
Honda mower won't pull start
you will need to find out if you are getting a spark. generally cheap to fix it you just need to find out which part isnt working first
Jun 03, 2012 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
I i have a honda htr3009 riding lawn mower that isnt getting spark wondering what could cause no spark
Mar 18, 2010 | Garden
HONDA 3011 LAWNMOWER RIDING HOW DOES THE BELT ON MOWER DECK GO ON? DIAGRAM
I dont have the diagram but remember the V of the belt aways goes in V pulleys and the back of the belt on flat pulleys . Honda provides you with diagrams at hondapowereqipment .com
Sep 28, 2009 | Garden
I have a honda riding lawn mower h4518h and i am not getting power to the ignition coil
check your safety fri st, be careful. remove the ground wire from your coil, unplug from spark plug. check your spark if no spark than more likely you have a bad coil. lite me know. good luck
Sep 18, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
