Question about Life Fitness Crosstrainer, 9100, 9500 Rear Drive Gk61-00002-0045
Life fitness crosstrainer keeps pausing and no resistance? plz help
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
Posted on Apr 04, 2013
I changed the 6 volt battery when i connect the battery leads and used machine i press clear/pause button it will start again. I have to disconnect the battery to turn it off
If no key is pressed for 15 seconds, and the user stops pedaling, the console shuts down. You can also do the same when starting the machine, just step on the pedals to get them moving and the console should light up.
Dec 13, 2014 | Life Fitness 9500 HR Crosstrainer Rear...
Tip
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Tip
95Xi Crosstrainer Shroud Replacement
Video Presentation of Replacing the Main Shroud on a LifeFitness 95Xi Crosstrainer
  • The video shows the steps involved in replacement of the main shroud on a LifeFitness 95Xi
  • Tools:
    • Phillips Screwdriver
  • Remove the (4) screws securing the main shroud to the drive frame assembly
    • There are two screws on each side
  • Lift straight up on the shroud to remove it
  • Install the main shroud in reverse order
    • Making sure the main shroud fits into the grooves of the lower shroud panels
Repair Video for LifeFitness 95Xi Crosstrainer Shroud Replacement
Tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer Elliptical
Tools needed:
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
Tip
95Xi Crosstrainer Pedal Replacement
Video about How to Replace the Pedal on a 95Xi Crosstrainer by LifeFitness
  • This video is about how to replace the pedal on a 95Xi LifeFitness crosstrainer
  • Tools necessary:
    • T40 Torx Driver
  • Remove the (4) torx bolts securing the pedal to the pedal lever assembly
  • Install the new pedal in reverse order
  • This completes the replacement of a pedal on the LifeFitness 95Xi
Life Fitness Crosstrainer 95Xi Video Pedal Replacement
on Apr 28, 2014 | Exercise & Fitness
Life fitness crosstrainer 9500 HR just shut down few second after start
Apr 04, 2013 | Life Fitness Crosstrainer, 9100, 9500 Rear...
95xi machine goes into pause mode when being used.
Check the gap between the magnet on the drive pulley and the reed switch that is mounted to the frame.
Aug 05, 2011 | Life Fitness Remanufactured 95Xi...
How to reaplce a battery on the life fitness 95 xi
u open top rear hood and you will see battery on there
Nov 19, 2010 | Life Fitness Remanufactured 95Xi...
Life Fitness Crosstrainer, 9100, 9500 Rear Drive Gk61-00002-0045 Logo
Top Life Fitness Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
sajeel1978 .
Level 1 Expert
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
