Question about Qca Spas Dream Series Dream Master Hot Tub with Flex Cover
Why doesnt my jets come on when filling hottub
Need to know wire gage
Copy following link:
http://waterheatertimer.org/Color-codewire.html
Add comment and say if each is wired separately, and how many volts.
Apr 13, 2013 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Hot tub won't heath up cal spa
Could be many things, please explain further.
Apr 11, 2013 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
My hottub want raise the temp above 89 on the control panel it says sl 89 i know it has three modes sleep mode econo and standard but how do i change the modes? the tub is a nordi sport
Some hot tub keypads have a 'mode' button. If yours doesn't try pressing 'warm/temp' followed by 'Jets'..... it's usually a combination of keys that changes the mode and this one springs to mind but I could be wrong.
Good luck,
Ian, from: http://hottub.synthasite.com
Jun 01, 2010 | Pool & Spa
Hot Spring Spa pump won't run just click on circuit board....
Check for voltage at the pump, before assuming the relays are out... then check for voltage before and after the relay contacts
Apr 08, 2010 | Pool & Spa
What do i do if i have put to much chlorine in my hot tub
You can drain some of the water to a sewer line or get chlorine netrulizer at your local pool store and add that.
Mar 09, 2010 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Flo word on panel nothing else works
'Flo' means that there's insufficient flow of water through the heater, or non at all.
1) Check the water level - top up if low.
2) Ensure that all jets are open and flow water - if they don't you may have a pump issue.
3) Remove the filter(s) and see whether or not this clears the fault, if so clean or replace the filters.
Regards,
Ian.
Mar 06, 2010 | RTO 2 Person Spa Hot Tub 8 Hydrotherapy...
Im tryin to tighten a hot tub tap that has no acsess panel to it . is there a way to tighten tap without cuting into wall ?
Without seeing the positioning it's hard to say. It should be possible, I know from my own experience that some unions can be incredibly difficult to access but I always find a way.
If you cant get access to it, would it be possible to lift the hot tub onto its side and gain access through the floor?... It would be harder but much neater than cutting the cabinet.
Regards,
Ian.
Feb 16, 2010 | Aqua Flo Spa Or Hottub 1.5 Hp Jet Dual...
Qca Spas Dream Series Dream Master Hot Tub with Flex Cover Logo
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
