Question about Samsung RF267AB (25.5 cu. ft.) Refrigerator
Cannot turn ice back on - Samsung RF267AB (25.5 cu. ft.) Refrigerator
Fghb2844lf1 ice machine is not work
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FGHB2844LF1, is not producing ice. I suggest turning your ice maker off and taking out the ice tray and dumping any ice that is in the tray. Wait 3-4 hours. Dry the tray out and put it back into position. Turn the ice maker back on. It will take anywhere from 2-3 hours for ice to produce. If your refrigerator is still not producing ice, please feel free to reconnect. Hope this is helpful.
-Best Regards-
WP
May 13, 2014 | Frigidaire Refrigerators
U Line Ice Maker not working at all
if your drain pump is the one you plug your ice maker into and then the pump into the wall plug the pump is full and will not let the ice maker run. must be something wrong with pump
Nov 14, 2013 | U-Line Icemaker
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice crusher stuck on crush mode can't swith back to cube
is it push button or do you manually have to turn dial from crush to cube. I have push button and had this problem once before.(LG side by side) I turned off at power (remove cord from wall) and removed ice tray all together. save some ice for testing. Check to see if crush part was clean. Put ice back in container and put back together and turn back on at power point. See if you can have cubed now.
Dec 14, 2009 | Frigidaire FRS3R4EW 33" 22.6 Cu. Ft....
Ice maker not making ice. do have water, no ice
The ice maker has a problem The ice maker is a separate appliance within the freezer section. Please see the How things Work section of our website to learn about the normal functioning of ice makers. Some common problems with ice makers are:
The ice maker has completely stopped producing ice
The ice maker is producing ice poorly
The ice maker has completely stopped producing ice Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Aug 29, 2009 | Kenmore Refrigerators
Arctica ice maker won't work without help
The solenold valve would not shut off completely & was leaking water on the paddle that the controls the icemaking. We replaced the solenold water valve & we now have ice!!!!! Good luck!
Feb 20, 2009 | GE Profile¿ Arctica® Energy...
Auger inside the ice bucket not turning - ice not dispensing
I had same problem. Fixed it by remove the motor at the back and spraying with wd40.
v_rampersad@hotmail.com
Dec 17, 2008 | GE GSS25SGMBS Side by Side Refrigerator
Ice maker stop making ice for kenmore 106.56352500
There's an ice- or water-dispensing problem The ice and water-dispensing system of your refrigerator is quite complex. Many components work together to provide the ice and water. Aside from a simple problem of a leaky water tube or a jammed ice chute, most other components are not user serviceable. We suggest that you contact a qualified appliance repair technician for such repairs.
Dec 06, 2008 | Kenmore 53642 / 53644 Side by Side...
Icemaker will not was dispense ice
My icemaker stopped producing ice. We turned off the water line to it when we went on vacation for a week. We turned the water back on when we got home and since that time it won't produce ice. We can still get water from the door dispenser though.
Nov 02, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RF267AB (25.5 cu. ft.) Refrigerator Logo
24 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
