Question about Ovens
Baumatic Cooker - Steam & Condensation Problem
We have a new Baumatic BT3062SS Electric cooker that we're concerned about - especially as we have tow very young children.
When using the main oven, especially when roasting meats, a large amount of steam comes out of the top of the door, over towards the right hand side. There does not seem to be a vent there, and it seems that once the oven has reached a certain pressure, it pushes steam out past the seal. The result is that is looks like a boiling kettle and a large amount of condensation collects on the smaller oven above and water drips down onto the floor.
I've already had a Baumatic engineer around and although he suggested on his visit that not all their ovens did this, he had seen a couple that did and could not explain why. However, his subsequent report back was that the cooker was/is within speicification.
I'ver had a number of cookers over the years and have never had one that performs like this. Can anyone advise if this sort of cooker behaviour is acceptable/normal?
SOURCE: Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Posted on Aug 01, 2008
barkencoa
  • 3463 Answers
SOURCE: Electric oven and hood not working but grill is?
Make sure the timer is set to manual and not on auto.
Posted on Dec 10, 2008
  • 193 Answers
SOURCE: Belling Electric Cooker - Main oven keeps tripping electrics
yes use an ohm meter to test it
Posted on Apr 29, 2010
SOURCE: Rosieres 4040DB cooker - Problem with oven doors
hi can you please give me a call re this... I have the same problem on my 4040db and I am keen to know if/how you resolved it, many thanks Simon 07787 511443
Posted on Oct 20, 2010
SOURCE: Condensation in oven door glass after steam clean
No solution--but I have the EXACT same problem--brand new oven and first time steam cleaned used. Wondering if you got any resolution with this...
Posted on Dec 12, 2010
My beaumatic oven fan light and heating up is not working but clock and timer is fine,can any one help
If you have a problem with your Baumatic B180 cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 20, 2015 | Baumatic B180 Electric Single Oven
HOW TO WIRE A SINGLE INTEGRATED OVEN? Can it be wired into the mains cooker point?
An integrated oven that has a 13 amp plug can be wired into a cooker point without any concerns since you are wiring it into a feed that is capable of handling a greater power requirement than is needed.
For the avoidance of doubt, the other way around, if you are considering putting a 13 amp plug on a unit that is designed for direct hardwiring into a cooker point, you should think again because it is probably capable of drawing more current than the 13 amp socket could safely handle
Jul 19, 2011 | Ovens
I have a baumatic cooker gas hob with an electric double oven model bt2730ss and i'd like to know how to remove the fan element? I took the plate off and undid the nut that holds the element in. Could...
hi if u have taken out the two screws then the element should be just sat there. make sure its turnt off at mains b4 going any further..... now pull element towards you slowly u should see the wires take one off at a time and swap over to new element ... when done put back together ... if u loose a wire down back just pull oven out and take back cover off to get access...
Feb 27, 2011 | Baumatic Ovens
Bottom oven on my cooker has stopped working, it trips the electric after 7 mins running but the top oven is fine why
hi there the most likely cause for this is the element going into a fault condition as it warms up and expands your best bet is to replace the element which isnt that hard to do yourself, you might also want to check that the fan is spinning freely as it may stick and overload
Oct 16, 2010 | Baumatic B905SS Stainless Steel Electric...
Good evening i have a BT2431SS baumatic cooker,i have no heat in main oven yet i have the hob and the grill that work ok.
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Nov 24, 2009 | Baumatic Ovens
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Feb 17, 2009 | Zanussi ZHQ575 Electric Double Oven
Fitting this cooker into an under bench unit
Yes
Should be no problem as long as you have some kind of vetilation.
Jul 27, 2008 | Baumatic B904SS Stainless Steel Electric...
Oven not heating up but fan and light on
oven not heating up but light coming on fan working and grill working . it allso heats up on other settings but not enough to cook
Jul 04, 2008 | Baumatic B187 Stainless Steel Electric...
Ovens Logo
96 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
