Question about Samsung LN32A330 32 in. LCD TV
Why am I unable to play DVDs on my TV since getting a Youview Box?
Samsung DVD Player. DVDs have worked with a Freeview box.
SOURCE: Lost ITV channels and C4
I have the same problem, can anybody help?
Posted on Jul 08, 2008
  • 133 Answers
SOURCE: dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Posted on Jan 11, 2009
  • 35 Answers
SOURCE: 42
sounds like it needs a re set
you need to press the following: (do not hesitate between presses)
s/by
info
menu
mute
s/by
when the tv comes back on follow original installation set up
Posted on Sep 04, 2009
  • 909 Answers
SOURCE: How do i tune freeview on my samsung ps42c7hd tv?
when you press DTV, press menu,setup,tuning and follow the on screen instructions.
Posted on Oct 11, 2009
SOURCE: Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Posted on Apr 26, 2010
Sony flat-screen bravia tv picture goes black but keeps playing audio when playing Netflix or DVDs.
your dvd player needs its own connection as does netflix and cable,get a new hdmi cable for each
Jul 11, 2015 | Samsung Audio Players & Recorders
Cannot record from tv to DVD Can play pre recordecdvd's
You cannot record from the TV as the TV doesn't give an output to the DVD Recorder.
You can only record onto DVDs from an external source such as Freeview, Cable or Satellite Box.
Jun 12, 2011 | LG DR-4912 DVD Recorder
Iv plugged a areial into the tv and a freeview digital box but i cant get a picture????
If you see the freeview box menu then the TV is not the issue.
If you can not see the freeview box menu then the TV is either not connected to the input correctly or the TV is not on the correct input. I little common sense goes a long way , use a DVD player or other device to check the inputs yellow is video in red and white are audio. If the inputs work with a DVD player and not the freeview box then the box is defective .
Sep 18, 2010 | Televison & Video
I have a Digilogic VCR/DVD player model DVDVCR1 connected to a tv with freeview already installed. But I am unable to record digital programmes from the TV.Will I have to bin my VCR/DVD player and replace...
I'm assuming you mean the recorder doesn't have freeview built in?
Then all you have to do is to get a cheap freeview box and just have it connected to your vcr via a scart lead. If the VCR has two scarts connect the one to the tv for playback and use the other for the box. If it has only one scart, then get a switcher box, there's some good ones on Amazon, that will allow you to select the different sockets and record from.
Nov 11, 2009 | Televison & Video
Connecting a freeview box
Your dvd player should be connected to the TV INPUT under norma conditionsl.What kind of recorder are you using? VCR player ?, Is it also a VCR recorder ( one cannot assume because I happened to own a VHS\vcr PLAYER, not player & recorder)Is Your VCR recorder? Then It must be connected to freeview box with universal scart to RCA converter box.You have "" dvd player in av2, vcr av1"" where? TV? freeview box scart connector ?
You will need scart to RCA converter box for sure.
Aug 08, 2008 | Televison & Video
We have purchased a Phillips freeview box but am unable to get a signal !! We have the tv arial plugged into the back of the freeview box into the tv and the scart connected from freeview to tv. Do we...
Yes
If the Freeview box is not connected to the main aerial socket, you cannot get a signal.
Also, you will need a digital aerial, if you don't already have one.
Jun 09, 2008 | Philips Televison & Video
Hi hope you are able to help. Although there is power to my panasonic SC-MT1 DVD player as indicated on the sub woofer and the DVD player I can not operate it. When it is first switched on at the mains...
Many thanks for your email and yes I have solved the problem. Unfortunately, the TV ariel that went in to the back of the freeview box was internally collecting water when it rained. The ariel runs down the roof and then down the outside of the house and some how water gets into and travels down the inside of the cable. The freeview box sat on top of the DVD player and the water ran through the vents in the freeview and dripped into the vents of the DVD player and that is why it no longer works.
Kind regards
Rachel
May 25, 2008 | Panasonic Televison & Video
Freeview box and dvd is not working
Have you checked the fuse in the plug for the dvd player?
Feb 18, 2008 | Televison & Video
Top box conns
your freeview box tv scart goes to the tv /the dvd goes to the aux on freeview and you can connect your vcr to the tv if it has a spare scart socket or the dvd player
Jan 14, 2008 | Computers & Internet
Will not play HD DVDs. & will not record
First off this is not an HD dvd player it is a dvd player that has HD upconversion. secondly if you want to record a cable show you will need to push that into the dvd recorder with the a/v input.
Dec 29, 2007 | Samsung DVD-R135
Samsung LN32A330 32 in. LCD TV Logo
13 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
