Question about Miele W526 Front Load Washer
How do i remove the display on a miele W526 - Miele W526 Front Load Washer
2 Suggested Answers
  • 70 Answers
SOURCE: Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Posted on Jan 30, 2011
I have a W526 and the machine fills water then drains, fills, drains....timer not counting down and fills water very high when rinsing
Sound like a problem with the pressure switch or hose. Some models and switchbbuilt-in to to main board
Nov 02, 2015 | Miele Washing Machines
How do I change the seal on a Miele W526 washing machine?
Dont remove eather!
Only the front!
Remove seal front ring on the front. Its one 10mm bolt under the seal on the front, undo this, and the two srews on the door lock. And two srews on both sides under the front. The the whole front is now loose and can be removed.
Then take of the inner seal ring, and unplugg drum ligths/hoses if any.
Replace seal....
May 07, 2014 | Miele W526 Front Load Washer
Cannot remove dispenser draweer on Kenmore model#417-44042400
it may have been jammed when shutting to hard try seeing if any of the plastic as bent inward and needs to be bent outwards so u can remove it :D..... also can u please answer my question :D
Jul 02, 2012 | Miele W526 Front Load Washer
I have a miele w526 wash machine .water leaked out under neath machine and 2 lights on side came on .check inlet and check drain .i turned it off removed clothes and tilted it forward and more water was...
In the bottom of your machine the is a tray in the tray the is a float, if the machine leaks the float lifts and hits a switch activating the two light on the facia. The is a leak either in the machine (sump hose) or around the machine drain etc. By tipping the machine you are emptying the tray thus allow it to work. You will need to find the cause of the leak. My best guess is the sump hose has been damaged by hair clip or pin. You may need to remove front panel to check hose etc.
Apr 09, 2011 | Miele W526 Front Load Washer
How to change miele novotronic W828 door seal?
Turn the machine off and unplug it! There are 3 10mm bolts around the door that need to be removed, the soap dispensing drawer needs to be taken out and you have 3 torx20 screws (one on the left and 2 on the right) that have to be removed. The bottom left corner of the machine there is a small door that you open, remove the hose that's clipped inside it, there is a small tab on the lower left, release the tab, pull open the door. To take out the seal you have to loosen the 8mm bolt band clamp, and pull the seal off. Fit the new seal on until you hear it pop. and reverse the order.
Hope it works for you.
Feb 28, 2011 | Miele W526 Front Load Washer
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele W 765 automatic washing machine Will not spin dry. All else is good.
Either your motor brushes are worn,the connection to the motor maybe defective or the tachogenerator is defective.
you would need to remove the front panel and investigate the issue if you are confident to do this. without knowing the tricks to remove the front panel and access the motor brushes and tachogenerator you might be better off having a service call. Miele have their own service team and service agents depending on where you live.
Hope this helps.
May 08, 2010 | Miele W526 Front Load Washer
Miele novo w526
Can you hear the drain pump running??....If so the WPS system has been activated and there is water in the base.
If not, please post back if any water is going into the main wash compartment once it's started. No water, then faulty inlet valve.
Jan 21, 2008 | Miele Novotronic Premier 500 Front Load...
Miele W526 Front Load Washer Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
