Question about Stoves Ovens
Stoves 600edo Can I fix my hobb. The dial isn't working properly on one hobb.
How to calibrate temperature dial on whirlpool gold stove oven
pull dial off and see if there is a small screw under it . that is how they used to work anyway
May 05, 2015 | Stoves Ovens
Stoves 058585102 manual
Hi:
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa
Jan 07, 2012 | Ovens
Stoves 720 EF double oven wiring diagram needed
Hi there:
Thank you for using FixYa.
Electric fan oven
Sounds like the oven thermostat stuck, for whatever reason and then the oven overheat thermostat kicked in. At the very least, I think you will need a new oven thermostat and possibly an overheat one as well. On the 720 there are two, one for each oven, so when you take the oven to bits, check both out.
Dec 17, 2011 | Stoves Ovens
Oven doesn't seem to heat up enough
There is a cooling fan In a STOVES 720 to keep the fabric of the oven cool. If this fails the overheat thermostats will cut in and shut the heating elements off. The cooling fan does in fact blow air out of various places in and around the doors. The top oven has a small element and takes a long time to warm up. If you are not confident that the thermostats are working correctly, then I suggest you purchase an oven thermometer from someone like Lakeland and see how that relate to what you are actually setting on the cooker dial. As I said the top oven leave a lot to be desired!
Oct 30, 2011 | Stoves 720EF Electric Double Oven
Hi I have recently moved house, and have inherited a Stoves 720EF double oven. The dials on the fascia, do they have a backlight, as the only way we can see the dials is shining a torch on the fascia! I...
I have just checked my 720 and when you turn any of the dials on a neon lights up near the dial to illuminate that particular dial. Now as far as I can see the diagrams in the handbook do not show the neons as such. However, they do show a 'neon printed circuit board' that has connections to all the switches. So if all the three neons fail to come on, it would suggest that the neon P.C.B. and/or its associated wiring has failed. I'm afraid you will need an electrician to sort it to conform what has failed. Espares may be able to obtain the part for you. If you need a copy of the handbook, (with diagrams) supply an email address and I will send you a pdf copy.
Jun 10, 2011 | Stoves 720EF Electric Double Oven
The bottom oven on my stoves cooker ignites but then constantly clicks and will not stop until the gas dial is switched off. Can any one give me a clue as to why? Thanks
As an ex stoves enginneer, the problem may be one of three faults;
1. cracked electrode, what creats the spark in the oven
2.electrode lead has melted.
3. faulty ignition generator.
Try takin the lead off the electrode and placing it in the oven flame, if this stops the clicking, then replace the electrode.
L.B
Jun 10, 2009 | Stoves Ovens
Cant work oven!
I have the Stoves 720EF manual stored on the BT Digital Vault which might help. If you want a copy of it, supply an email address and I will give it access.
Also someone else has said that if you speak to Stoves nicely they may be able to send an electronic version of the manual instead of the paper copy.
Nov 27, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
20 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
