Question about GPS
F8l 250v fuse - GPS
Do i have a blown fuse if I am checking 2 small fuses that are on a circuit board. one is 1.6 amp 250v and the other is 160ma 250v and the 160ma fuse is the one testing 1.4 and the 1.6 amp fuse is tes
They have a restorside, a bit , that's why you have fast and slow fuses. But if they were dead, then the resistant would be infinite, so
no problems with both fuses.
gr. Richard
Sep 12, 2014 | Roland Cube Street - Battery Powered...
Jvc compact component system mx-gb6. what amp fuse do I need
There are 2 fuses that i can see in this model
RFS2 250V 6.3A
RFS6 250V 8A
RFS6 250V 8A
Jul 12, 2014 | Audio Players & Recorders
I have a pair of Technics SL-1200MK@ Turntables and I blew the fuses on the curcuit boards. I'm having trouble finding a discontinued fuse. If you know anyone selling them, please post some links for...
Any decent electrical shop should have those fuses. They tend to come in 20mm and 30mm lengths. You will need to know which. Also there are fast blow and slow blow fuses. If you have the originals and you can see the remains of a coil then you want slow blow. Otherwise just replace them with fast ones. The 1.2 amp fuse can be replaced with a 250 volt fuse.
So you want a 250ma 250v fuse.
and a 1.2A 250v fuse.
Oct 07, 2017 | Audio Players & Recorders
I have just brought a Ikasu f8l 904 but it has come without a manual does anyone know where I can get one so I can set up my tv.
If you just go to google and put in, manual for a Ikasu f8l 904, it gives you various options a few of then are so you can download the manual.
Dec 29, 2009 | Televison & Video
Looking for a replacment fuse #T3.15AL 250V
The cheapest place I have found is amazon. here:
QUALITY USA brand fuses Set of 5 pieces T3 15AL250V T3 15A 250V T3 15L250V... (you can search from another sellers, but this one had most positive reviews). I hope this was helpful. cheers
Jun 07, 2009 | Goldstar DH504EL Dehumidifier
PC power supply fuse - T6.3h 250v engraved on end
T = time delay (slow blow)
6.3A = 6.3 Amperes maximum load
H = HRC - high rupture current (as you specified a ceramic fuse)
250V = 250V AC rated
other letters you may see
FF = ultra fast blow
F = fast blow
M = medium blow
TT = very slow blow
L = low blow current
H = high blow current (glass package)
S = sand filled
Apr 02, 2009 | Dell Computers & Internet
Fuse
Its actually a 7A 250V fuse. Unfortunately, I have not had any luck finding it. Also, 7A 250V fuse come in two sizes, a large and a small. So you will need the small
Aug 03, 2008 | Belkin TuneBase FM (F8Z049-BLK) Car...
Reaccuring problem
The main fuse, it should 5A/250V. The one you bought is 0.5A/250V and it will burn because it can not handle the amount of current that passes through it.
The other fuse that sparks even when the TV is unplug because is the charge of a capacitor that circulates when you place the fuse.
Just curious why you had to change the fuses?
Mar 06, 2008 | Philips 60P8342 60" Rear Projection...
Philips 60PP9202/17F Fuses are gone
I can't believe he pulled them all, but here's a list of all the fuses and their ratings from the service manual:
S 1000 Fuse, T 5A IEC
S 1300 Fuse/Clip, 5 Amp, 250V
S 1801 Fuse, 2 A, 250V IEC
S 1804 Fuse, LT 1A, 250V, IEC
S 1805 Fuse, LT 1A, 250V, IEC
S 1700 Fuse, 2 A, 250V IEC
S 1701 Fuse, 2 A, 250V IEC
1003 Fuse, 500MA, 50V, UL
Jan 12, 2008 | Philips 60PP9202 60" Rear Projection...
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
GPS Logo
54 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
