Question about LG RU-52SZ30 52" Rear Projection Television
1993 52 inch rear projection rca tv
When the unit is powered on, it comes on and then shuts off. Using either the switch or a remote.Any thoughts?
  • frankjill Feb 07, 2008
    Hi Moviebuff,
    We have the same problem with our LG RU52SZ30, I took it to a TV repair place and they said I needed to change the chassis which is a $1800 excersise which is nearly as much as the tv. I haven't done anything with it.
    Have you had any luck as your problem sounds the same as ours.
    I am sure it is just one component which is apart of the chassis, finding which one is the key.
    Any input would be great.
    Problem Solver:
  • 13 Answers
I have this kind of tv1993 52 inch rear projection rca tv - 1.gif model ru-52sz30 and same problem which i fixed by replacing the bulb. there is an access door at the back of tv that you can replace the bulb. if you need more help just post reply again.
Posted on Feb 07, 2008
I have a 56 inch rca rear projection tv and after two hours starts turning of and on for about half hour and then turns off. when we turn it back on it shuts off and comes on fast and then shuts off....
Those type of tv sets get unusually hot at times. Could be a heat issue. Power flow at night is the best. If it's still turning off then, it must be a dust or heat issue.
May 08, 2011 | RCA D56W20 56" Rear Projection Television
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Your TV is overheating.. easiest remedy is to point a fan at the back of the TV or... clean the inside of the TV, Im sure its full of dust and stuff... this prevents air circulation inside the TV thus creating more heat...
Jun 19, 2009 | RCA HD52W56 52" Rear Projection HDTV
Tv turns off and comes on
have u been using the buttons on the front?
if so it could be the button is stuck on the tv..
or possible a short in ur remote..
Jan 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
RCA Projection TV
ok lets begin... shut off? the set staying off. NO POwer at all.. does the set try to come on. does the set have a blinking led on front. have you tried unpluging then waiting 30 min then trying to turn it on again.. this set has a processor and when it detectect any fault will shut the set down
Mar 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
56 inch RCA rear proj T.V.
Sounds like the capicator on the high voltage is swelled,removing the back cover,make sure to unplug the unit first,there is a u shaped heat sink about middle ways of the board,inside that heat sink is a cap,it will be swelled on top of it,its a 2200 35v cap.
Jan 05, 2008 | RCA D56W20 56" Rear Projection Television
Tv loses power
the processor on this et will shut this set down for number of reasons. a technician should be albel to read error codes form the processor to help deterine whatt is cause the shutdown
Nov 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
LG RU-52SZ30 52" Rear Projection Television Logo
143 people viewed this question
Computer Repairing
Computer Repairing
