I have a buzzing sound in the engine. It goes away when I give the car gas. It comes back whenever the gas pedal is depressed. The buzzing also sounds different depending on the level the A/C is set on.
Thanks for your feedback. If it is one of those issues will it hurt anything to continue to drive it until I can get it to a mechanic?Thanks for your feedback. If it is one of those issues will it hurt anything to continue to drive it until I can get it to a mechanic?
try to go as soon as posible you dont want your ac compressor to go bad is about 500 dollars, and if you have a bad pulley it can brake a belt but you can drivetry to go as soon as posible you dont want your ac compressor to go bad is about 500 dollars, and if you have a bad pulley it can brake a belt but you can drive
The sound you hear, is it a whining, popping, grinding, scraping or rattling sound?
If you drive a manual transmission vehicle and notice a grinding noise, it can indicate the clutch gear is no longer disengaging correctly.
After the gas light goes on in a Toyota Corolla, you can travel 46.55 more miles. But I would stop and get gas right away, just to be safe!------------------------------------------------------------------------------------------ VAS 5054A V19
with engine running?? assuming noise is under hood here is one possible cause. sometimes pcv valve will make a buzzing noise as the little ball in there flaps around when spring gets weak. locate your pcv valve and feel it if this is noise you will feel the hose vibrating and if so replace valve
We've have the same problem with ours. We found the fuel canister needed replaces. It's mounted near the back bumper with straps. The part cost us about 125 bucks and was pretty easy to replace. The trick is to get the bolts out without snapping them.
Thanks again. You've been very helpful.
