Question about NetGear Computers & Internet
How to change the number of rings on a netgear MVBR1210c hub
How can I change Passphase on my new Suuper Hub?
Hi there
I presume you are referring to the Netgear / Virgin Super Hub.
Yes, you can change the passphrase for the Super Hub. Below is a link to the manual for the Super Hub. Go to page 14 and start there.
http://setuprouter.com/router/netgear/virgin-media-super-hub-2/manual-1041.pdf
Aug 12, 2014 | NetGear Computers & Internet
GS605 v4 netgear
Move your primary Internet connection to port number 5. Although it is not mentioned in any of the documentation, Port 5 is the uplink port.
Feb 25, 2012 | NetGear GS605 5Port Gigabit Ethernet...
What is the replacement fan for Netgear FS524
Just took mine apart and the fan is Sunon KD0504PKB2
Jan 13, 2012 | NetGear FS524 24x10/100 Mbps Networking...
We are trying to connet one Netgear hub to another Netgear hub
To connect one hub (switch) to another you have to use the Uplink ports. You cannot use the port next to the Uplink port if you connect them via the uplink..
Dec 07, 2010 | NetGear Computers & Internet
I have a netgear ds116 hub and i want to set up a linksys router
Here's what you can do. Don't connect the Linksys router yet to the hub. Connect 1 computer directly to the Linksys router. Access the router's setup page of the Linksys router thru http://192.168.1.1
It will prompt you for username and password. No username and password is admin.
Look for Local IP Address or LAN IP Address. Change the LAN or Local IP Address of the Linksys router to 192.168.5.1 then click on Save Settings at the bottom. Right after saving the settings, unplug the power of the Linksys router, connect it to the hub and it should be good to go.
Oct 06, 2009 | Linksys Wireless-G WRT54GS Router...
My netgear WG111t does not connect to my BT HomeHub
wths the color of the hub u have is it while or black one with the blue lights
if u forgot the passphrase at the side u ll have reset to default button will b there press for 15secs and wait for it to reboot and at the back u ll have the wireless key u can use it or the passpharase at the hub can be used, and if u want to change u can go to the routers page and u can change it manually
for further assistance pls gemme back with the error code and version of the hub if not the lights on the hub for the furhter assistance
May 22, 2009 | NetGear WG111T 108 Mbps 802.11g Wireless...
Netgear FE108 connections
You must configure the other PCs in the same IP range of the netgear. fexample: if the netgear ip adress is 10.0.0.1 then the other PC should have an IP like 10.0.0.x (x = any number from 2 to 254)
Sep 24, 2008 | NetGear FE108 8-Port Ethernet Hub...
Netgear FR114P with Netgear DS108 not working
DNeser, Port forwarding and static routes isn?t the route to go down to fix this issue. I have an FR114 in a similar configuration and yours should work as well. -When connecting a hub to a router you should be using a certified, standard Ethernet cable, not a crossover. Make sure it?s certified for at least 100 Mbps. -If you are using port 8 on the hub to connect to the router make sure the Normal/Uplink button is set to Normal. -Are the Link and 100 Mbps LED green on both the hub and router ports you use to connect? If not try a known good cable; if that doesn?t work try different ports. Let us know how things work out and please don?t forget to rate this post.
Feb 24, 2007 | NetGear FR114P Router
Computers & Internet Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
