Question about Whirlpool GY399LXUS
We are using a 3ph electrical service. The GY399LXUS will not heat up. Is there any special wiring or procedure you need to do?
Tail light fuse keeps blowing and melted harness by tail light
Your have a short to ground , you know how to test automotive electrical circuit's ? They have special tool's to find shorts . Do you know how to repair electrical wire's , solder , protect with heat srink ? Video's on youtube .
Electric Testing Techniques You Need to Know
Basic Electricity for Service Techs Ohm law Current Flow Opens Shorts
How to test for short to ground ohmmeter vs test light
How To Fix and Repair Automotive Wiring Harness
Dec 20, 2017 | Cars & Trucks
What size generator do I need to run a 10 hp motor
on the plate attached to the motor you will find several important items
one is the wattage of the motor
this is the maximum wattage that the motor uses when under load
the gen set will need to be at least 30% bigger than that figure
next there will the number of phases that the motor is
it will read as 1 ph or 3ph
If it is 1ph that is a single phase motor and will ru from a single phase gen set
however if it is 3ph you will need a 3ph gen set to run the motor
As most single phase motors are limited to around 5hp I would be very sure that the motor is not 3ph
specialist advice from an accredited electrician or electrical motor shop is recommended before buying a gen set. as if you need 3ph the gen sets become expensive.
Aug 07, 2015 | Electrical Supplies
I need a wire diagram for a high voltage Baldor motor CAT # 054180 79151 connect to 440VAC it's a 40HP, RPM 3525 , 3PH and it's SPEC# 40F97Z22 please help
Normal wiring for this type of 9 lead motor to 440VAC is
Connect #4 to #7 Connect #5 to #8 Connect #6 to #9
Connect supply phase A to #1 Connect supply phase B to #2 Connect supply phase C to #3
Can you confirm the CAT and SPEC numbers? They do not show up on the Baldor site. If they are correct as listed, you need to call the Baldor help line and find out if this is a special motor.
Aug 05, 2010 | Gb Electrical 100 Amp GE Load Center
Ge jsp42 electric range ..Oven heats up very slowly..sometimes can take one hour to heat to 400 degrees..Stove top also slow..
Check the voltage at the outlet. It should be 208v or 240v. check by putting meter probe into the 2/3 slots. NOT the U shaped,or round looking holes.Check one to another. Check tag on range for voltage of range. If you have 208v at the outlet and range is 240v the oven will take forever to heat, it is not getting the power it needs. If the tag says 230v either will work. On the oven tag it will say either 1ph, or 3ph. If it says 3ph you outlet should have the voltage mentioned above between ALL 3 SLOTS! If you get 120v when testing any slot, you have only 1ph of power. Keeping it simple, the ph, (or phase,) between the outlet and oven have to be the same.
Mar 31, 2010 | GE JSP42 Electric Kitchen Range
Unit comes on and runs for 5 minutes, the circuit trips off
30 is the correct size breaker for this unit. It sounds like there is a grounding issue going on in the system. Or off of the Thermostat. Something is grounding out causing the switch to trip. Are you running #10 wire to breaker and the unit? If not you will need to increase your wire size
Jan 03, 2010 | Dayton D-F79 Electric Space Heater- the...
We have a Vulcan Roast Oven VO008 and it is wired for 480 volt 3ph, can it be rewired to be 240 volt single phase?
It could be but, the expense of replacing all the 3 phase controls would cost more than what it would be worth. Sell it and use the proceeds to purchase a single phase unit or if you are wanting to use it in a commercial building, see if you can have 3 phase installed by your electric provider.
Jul 07, 2009 | Ovens
Where's my O2 sensor located
Heated Oxygen Sensor (HO2S) SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Oxygen Sensor Wrench T94L-9472-A
Removal and Installation
NOTE: If excessive force is needed to remove heated oxygen sensor (HO2S) (9F472) , lubricate heated oxygen sensor with penetrating oil prior to removal.
  1. Disconnect battery ground cable (14301) .
  1. Disconnect heated oxygen sensors from engine control sensor wiring (12A581) .
  1. Raise vehicle on hoist. Refer to Section 00-02 .
  1. Remove heated oxygen sensors from dual converter Y pipe (5F250) using Oxygen Sensor Wrench T94L-9472-A.
  1. To install, reverse Removal procedure. Tighten heated oxygen sensors to 36-46 Nm (26-34 lb-ft).
Feb 22, 2009 | 1994 Ford Thunderbird
Range
Yes your oven will work with 3 ph wiring. You need to wire it looking at the back where the wires attach Black, White, Red. Now the red and black can be reversed they both are the hot input that is what makes 240V. also here is an manual if you want to download.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0803193.pdf
Good Luck and Please Rate FixYa!
Dec 28, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Wire up a 3 phase motor to single phase 240v power
3ph motors will only run on 3ph power, trying to single phase will only burn up windings,
Dec 12, 2007 | Heating & Cooling
Whirlpool GY399LXUS Logo
55 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
