Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Bizhub c253 error code c4151 - Konica Minolta bizhub 350 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,696 Answers
Motor inside the print head for cyan image unit is bad, Print heads are located below the image units one for each color. will need a tech to replace.Open close front door to reset
Posted on Dec 30, 2015
nchalabe
  • 4 Answers
SOURCE: Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Posted on Jul 09, 2009
SOURCE: howto fix internal error c - 1183 on bizhub c253
C-1183 - Finishing option elevator drive malfunction
Posted on Aug 23, 2009
  • 158 Answers
SOURCE: I have a BizHub C253 and the data light just
most common cause for this is the hard drive in the copier is malfunctioning and needs to be replaced or data clear needs to be done in service mode
Posted on Oct 03, 2009
  • 51 Answers
SOURCE: Bizhub C253: Error Code C-4551 will not clear.
open front door and switch-off machine
press utility buton hold press-on then swietch-on machine, on the screen right top corner u see dot (remove finger from utility buton)
after fue second u will see trouble reset touch under u will see ok switch-off machine wait 10 sec and switch on
If the error code still is on the machine u have to change cyan laser
Posted on Oct 09, 2009
  • 158 Answers
SOURCE: How do I clear error message C-2558 for the Konica
tis error means abnormal tonder density in the balck image unit take the blacke image unit out and shake it while holding it level and put it back in the machine to reset the error code leave the machine on and open then close the front door
Posted on Nov 16, 2009
Konica minolta bizhub C253 is showing me trouble code C- 2556. What should I do to pix this problem
Konica-Minolta bizhub C253 Trouble Error Codes List page 4
Code C2556
Abnormally high toner density detected yellow TCR sensor
• TC ratio in the developing machine, which is determined by toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively. • When the connector of the TCR sensor is disconnected.
Solution:
1 Reinstall imaging unit. 2 Reinstall toner cartridge. 3 M3, M4 operation check (At this time, IU must be non-installation.). 4 Change imaging unit. 5 Change PRCB
Extract from:
http://www.printcopy.info/?l=en&mod=free&chap=erc&brand=Konica-Minolta&model=bizhub%20C253&page=4
Nov 14, 2015 | Konica Minolta Office Equipment & Supplies
I have an error code C5370, which will not clear. The Service rep is stumped at this point. Originally, we had a glob of toner that gummed up the works, and he took the entire machine apart to find t
See the link below: looks like a cooling fan error code and the fan needs repalcement. You got a GOOD REP oh yeah...
http://www.copytechnet.com/forums/konica-minolta/27391-bizhub-c253-error-c-5370-a.html
Sep 29, 2014 | Konica Minolta Bizhub C253 Copier
Konica minolta bizhub c253
what is the question?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Konica Minolta Minolta Bizhub C253 Copier
How can I solve error code c255A
From another site
Details Subject:
C-255A (C255A), C-255B (C255B), C-2559 (C2559) or C-255C (C255C) at power up.
Description:
C-255x code at power up.
Solution:
CAUSE: The K (black) IU (C-255C) has failed. The M (Magenta) IU (C-255A), Y (Yellow) IU (C-255B) or C (Cyan) IU (C-2559) is not fully seated or has failed.
SOLUTION: Replace the K (black) IU (Item #A0DE02F for the bizhub C203/C253 and Item #A0DE03F for the bizhub C353). Reseat the color IU and if the problem persists, replace it. Item # Color IU Model
A0DE0CF Magenta bizhub C203/C253
A0DE0DF Magenta bizhub C353
A0DE06F Yellow bizhub C203/C253
A0DE07F Yellow bizhub C353
A0DE0HF Cyan bizhub C203/C253
A0DE0JF Cyan bizhub C353
SPECIAL NOTE: Solution contribution by Tom Kelly, Workgroup/SSD
Options:
None Specified Details Subject:
After toner installation, C255x code within a few hundred prints.
Description:
C2551, C2553, C2555 or C2557 codes.
Solution:
CAUSE: Toner is not supplied due to abnormal position of coupling.
Normal condition The coupling is blocked by bracket
May 03, 2014 | Konica Minolta bizhub C250 All-In-One...
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
Aug 06, 2013 | Konica Minolta Bizhub C253 Copier
What is error c-2527 of konica minolta bizhub c253
sorry, cannot find that error code in SM. Are u sure is it correct code?
Jun 28, 2013 | Konica Minolta Bizhub C253 Copier
MY KONICA MINOLTA C200 IS DESPLAYING AN ERROR C4151
restart the machine.
If error code appears call your tech services rep.
Feb 15, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
654 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
