Question about Philips Car Audio & Video
How do i reset citreon balingo radio - Philips Car Audio & Video
HOW CAN I GET A RADIO CODE FOR A CITREON CLARION RADIO
You need to go through a Citroen dealer to get the code.
Feb 26, 2015 | 2001 Citroen Xsara Picasso
How do I set the time and date in a citreon c8 that does not have the original radio in?
what is the make and model of the radio your having problems with ?
Jul 08, 2014 | 2007 Citroen C8 2.0
Citrion balingo runs ruff when cold petrol
Add some gasoline (petrol) antifreeze to the petrol each fillup in cold weather. Also, have the choke heater checked to see if it is working properly.
Jan 12, 2013 | 1994 GMC Jimmy
Can you put a vin code into a non citreon cd player
no.
if its an after market product. there is no need for code
Jul 01, 2012 | Citroen Xsara Cars & Trucks
Need the radio code for a citreon
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Jun 18, 2011 | Car Audio & Video
Need 2 unblock my car stereo citreon saxo 53 plate lost code when battery changed citreon said 20 quid but because car 2nd hand cant garantee code will b correct
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Remove the radio from the dashboard.
Aug 10, 2010 | Car Audio & Video
I have recently purchased a Citreon Synergie 1.9 td sx reg no R429CKK ,the battery was disconnected so it,s lost the radio code ,can you find it
The radio code should be located on a sticker on the back cover of the owners manual, If the manual is not available then you will need to have the code reset by a local dealership.
Aug 10, 2010 | Philips Car Audio & Video
Unlock my radio citreon saxo
diconnect the battery for a long tinem (at least 45 minutes) then reinstall the battery and the factory defauly values should now be in it and not your code.
Jan 07, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Car Audio & Video Logo
26 people viewed this question
Top Philips Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Matthew Spark
Matthew Spark
Are you a Philips Car Audio and Video Expert? Answer questions, earn points and help others
