Possible overclock is it possible to overclock the msi 7191 motherboard. most boards have jumpers to enable clocking but this one doesnt or i cant find them,any ideas?
  • 90 Answers
New boards will have all of those options in the bios.
Posted on Jun 22, 2009
    Sergeant:
  • 220 Answers
Overclocking is now set on bios.
Just change the multipliers for desired speed, but be careful
I have msi 7191 Motherboard ver 1.1. But lost onboard sound driver. Kindly help for onboard sound driver for ms 7191 ver1.1
go to the msi site/ support section/ select *********** board model and operating system i.e XP or win7 or other. all drivers are available there. download, install and enjoy
Aug 29, 2011 | Computers & Internet
Tip
MAKING YOUR COMPUTER OPERATE VERY FAST & SECURED THROUGH CPU OVERCLOCKING
NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN
drbrightirem.jpgOverclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
  • NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN Tips & Warnings
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    on Dec 06, 2010 | Computers & Internet
    Msi ms 7191 motherboard display drivers
    You can download the drivers from MSI WEB support site,select your model motherboard to download :-http://www.msi.com/index.php?func=downloadindex
    Jan 30, 2011 | MSI RS482M4-IL MS-7191-040 (Retail)...
    I need to disable the onboard video by finding the jumpers on the motherboard (MSI 7191 Version 1.1). When I installed a new PCI card (because the onboard video is broken) the computer freezes up and...
    Go to the device manage and instead of disabling it, uninstall it. Then power down, move the cable to the pci port. reboot, when windows brings up the new hardware found, hit cancel until it disappears. Go back to device manager and if it has re-appeared uninstall it again and go about your business.
    Sep 06, 2009 | MSI PM8M-V Motherboard
    How to overclock my motherboard ?
    there are 2 ways, overclocking using the bios to over clock the memory ( ram ) and also the processor ie changing the multipliers and other tweaks ( which should be in your motherboards manual ) that or using jumpers which are physically on the motherboard but later motherboards use the bios to tweak / over clock your computer.
    Apr 13, 2009 | Computers & Internet
    Overclock
    I do not condone overclocking!
    You can try upgrading your bios to the latest version. It may let you change the CPU settings.
    http://downloadcenter.intel.com/Fi [...] &strOSs=38
    Intel boards are usually "locked" (BIOS), and are difficult if not impossible to overclock.
    I DO NOT CONDONE OVERCLOCKING. IT CAN RUIN,TRASH, BREAK FOREVER, MAKE CEASE TO FUNCTION, if something goes wrong, not yelling at you just want to make sure you know what you are trying toget into.
    But...They do sell boards designed for that purpose, I think you can get the board you have w/CPU for under $100. Look for a different board if you are serious about it.
    Mar 29, 2009 | Intel PENTIUM E2200 LGA775 2.20G 1MB...
    I have a probleme with a MSI 945P NEO5 Motherboard CPU install is an Intel Pentium4 3.0MHZ. The problem is the voltage reading is out of specification in the semos and even when analising it with the...
    It seems like your board has been overclocked you must enter BIOS
    2 methods to do so
    1) Press one of these keys to do so
    DEL F2 ctrl + esc.
    or check lower part of screen during boot up will tell you which key to press.
    When in BIOS reset to "Default" and see how you go
    2) check M/board somewhere on it will be BIOS reset pins
    either a 2 pin setting with no jumper across them fit jumper across them for 2/3 minutes then reset to normal and boot.
    Or a 3 pin setup change jumper across middle and other pin 2/3 mins then reset them back to standard
    either method should do to reset BIOS to default
    Jan 28, 2009 | MSI 945P NEO5-F Desktop Board - Core 2...
    MSI MS-7142 motherboard problem
    try cleaning CMOS with cmos jumpers or just remove your battery of motherboard for 10 seconds (previously unplug power from PC.)
    Jan 31, 2008 | MSI K8MM-V Motherboard
    I tried to overclock it
    Doesnt sound good - When you said you reset the bios that meant you reset the CMOS jumper on the mainboard?
    If that doesnt do it then i would try just one stick of ram at a time.
    You may even have burned up the CPU trying to overclock it so far. If you could find another athlon xp then i would try that last.
    If that isnt practical then it is likely the mainboard is shot.
    It would probably be best at that point to use this as an excuse to upgrade to a newer platform - an athlon x2 5600 with mainboard and RAM is only about $200-$250 depending on the combo you get. Keep in mind most newer boards will use PCI Express instead of AGP video cards.
    Dec 20, 2007 | MSI K7N2 (MS-6570) Motherboard
    Computers & Internet Logo
    222 people viewed this question
    Alun Cox
    David Payne
    David Payne
