Question about Pentax Optio A40 Digital Camera
Is there aVideo to fix LCD screen Pentax option s6?
5 Suggested Answers
Bogdan
  • 198 Answers
SOURCE: Lots of noise lines in picture screen
This is a fairly tipical sensor related problem. A sensor CCD or CMOS will use 3 areas of transistors, each of them managing a single elementary color (RGB - red green blue) in order to capture light and compose the picture. The white color is the most complex wave lenght color that a camera can detect. It will record it by combining all those 3 areas of transistors and balancing the amount of red green blue and their saturations to achieve a fairly good aproximation of the white color (thus a white balance model is used to help the camera to easier recognise a white reference point when taking the picture). If the white becomes pink this means that not all of the transistors were used when "reading" the light. If the pictures have too much noise or are difficult to take or see on the display of the camera, it also means there is a problem with the connections between the small transistors in the sensor, more exactly imperfect contact, a smaller control voltage than the minimum required and similar. However, in most of the cases, the sensor itself isn't the problem, that would be the small ribbon like cable connection that links it to the camera's mainboard. If this cable doens't make a good electrical contact with the sensor or with the other end - the mainboard, the signal comming and going through the sensor will be distorded or have missing components. That's the most common situation. Excess moisture, shocks or other factors may damage or weaken the mechanical contact holding the cable connected to it's ends. This should be checked out first, before asuming other causes for the problem. However this requires dissasembling the camera. While the exterior body of the camera may be taken apart by unscrewing some 3-4 screws, the lens assembly is a very fragile component. If it's not handled with care and some specialised tools it will break down, or some small servomotors may become loose. The actual sensor is located inside this lens assembly. It's a very small rectangle shaped object just underneath the back of the lens assembly. The cable running through that area must be checked by in a specialised service center as taking apart the lens mechanism is a very complicated job.
If you need more informations please reply with your questions.  or if you however want to do this yourself (once again, i think it would be very recomandable not to) i can give you some instructions on how to do this.
Posted on Oct 23, 2007
  • 3 Answers
SOURCE: pentax optio s6
perhaps mazzachris would be interested in unloading his/her E10 LCD to me?  My E10 LCD is cracked.
Posted on Nov 05, 2007
spotatohead
  • 95 Answers
SOURCE: NEED MANUAL FOR PENTAX OPTIO DIGITAL CAMERA S6
Since you asked so nicely, here's a link to the manual:
http://www.pentaximaging.com/files/manual/Optio%20S6%20Manual_web.pdf
Posted on Jan 06, 2009
richard191
  • 691 Answers
SOURCE: i ahve the pentax optio s6 camera. the camera
Hello
Thank you for using FixYa for your problem
Sounds like the LCD is faulty, but there are a number of things that can cause the LCD to play up too
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 01, 2009
Testimonial: "thx for your quick reponse. very helpful"
My pentax optio s6 fell on the floor and does not turn on...
Gmail is the network provider that makes available several features. First, emailing is an option to message between persons. Another feature to message is the chat. Gmail bundle of softwares may have been provided with a chat program. Inspect the computers list of mail programs to ascertain an minimised chat windows making possible messaging. In the situation that Gmail did not provide chat programs, yahoo chat may replace the as similar requests.
Feb 06, 2011 | Pentax Optio S6 Digital Camera
Broken screen,must have fallen? is it worth fixing
I can fix this for $40, or you can send it to Pentax in Arizona, they will replace the LCD for about $90. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Contact me at: mrfixitmark at comcast dot net
Dec 29, 2009 | Pentax Optio A20 Digital Camera
I ahve the pentax optio s6 camera. the camera
Hello
Thanks
Richard Scott
Technical Support
New Zealand
Dec 01, 2009 | Pentax Optio S6 Digital Camera
How do i focus on close objects like flowers
Go into "macro" mode. Press the button with the picture of a flower and a mountain until the flower appears on the lcd screen.
Oct 12, 2009 | Pentax Optio S6 Digital Camera
Screen appears just white on my pentax optio a20 camera
You need a new LCD display.
I can replace the screen for $40, or you can buy the parts on eBay for about $25 and do it yourself if you are very handy, and very skilled with small delicate parts. You could send it to Pentax in Arizona, but they charge about $90 for an LCD replacement. If you just want to get rid of this camera, I also buy all Pentax Option a10, a20, a30, a40 cameras.
Nov 18, 2008 | Pentax Optio A20 Digital Camera
Pentax optio s6
Sep 03, 2007 | Pentax Optio S6 Digital Camera
Pentax Optio A40 Digital Camera Logo
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
