Question about Sharp Computers & Internet
Sharp aquos lc52d62u main board - Sharp Computers & Internet
  • 53 Answers
SOURCE: Sharp Aquos HDTV LC52D62U Caption Not Readable
Try doing the Factory Initialization (WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go
  5. then at the same time press “Vol –“ and “Ch. Down”, you should see the service menu appear (if it does not appear, try pressing the two buttons again, it needs to be exactly at the same time)
  6. Then use the “Ch. Down” button to navigate down the service menu until you see “Industry Init” (NOT Industry Init +cause)
  7. Then press “Vol +” to toggle it to “ON”
  8. Then “/////////////////” should appear.
  9. when the screen turns GREEN, unplug the TV. Wait about 30 seconds, then plug the TV back in.
  10. Then continue on with the initial setup again.
This puts the TV back into the “fresh out of the box” settings. See if this helps with your CC problem.
Posted on Mar 16, 2008
  • 1156 Answers
SOURCE: my 46" sharp aquos tv does not turns on only a
You might wish to unplug the TV for an hour or more. If this power reset does not allow the TV to turn on component failure is indicated. These sets are assembled using the wave soldering process they are known for having cold solder connections.
The safety circuitry shuts the TV set down or will keep it from turning on when it detects a problem. This model of TV has over 2,000 parts, which includes millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Diodes and IC can go bad.
This may have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again if the parts that caused the failure to begin with are not replaced.
The only way to know for sure which parts that are no longer within factory specs and for a proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment specifically designed for TV service and the skills to use the test equipment. I wish I could tell you there was a quick fix or button to push that would fix the TV but that is not the case or the solution needed to get the TV operating correctly.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
You might need to replace the power board again...
I hope this helps.
Posted on Aug 07, 2011
vinceisaac
  • 2432 Answers
SOURCE: Sharp Aquos LC-C3237U no picture backlight OK green light on
check if their is a signal on voltages around 3.3v at the inverter board if none their is a problem in the board which is in the processor.
Posted on Aug 31, 2012
gopakumarg43
  • 74136 Answers
SOURCE: sharp aquos 37 lcd boards problem
What is the problem you faces with this TV? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 26, 2014
  • 12935 Answers
SOURCE: My Sharp Aquos 60 inch TV was hit by lightning and the hdmi and av ports do not work IF I replace the main board will this help?
Yes, since the inputs on these sets are located on the main board only.
Posted on Nov 23, 2015
Sharp aquos tv won't turn on with remote, replaced ir board, still not working
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 18, 2016 | Sharp 60" LC-60LE650U AQUOS Full HD Smart...
Hi my sharp aquos lc-30hv4u keep's blowing the main ac fuse 3.15amp 250v. i looked at the main power board it looks good. is there something i can look for? thanks for any help.
On the power board look at the electrolytic capacitors . The top of them should be flat. If they are domed on top or have leaked out the bottom then they need to be replaced.
Mar 13, 2011 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
I have a Sharp 52in model LC52D62U.The (on) light blinks on an off 2 time an the (opc) light blinks on an off 5 times. Can you tell me what this code meanes. If that is a code.I can not turn the TV on. IT...
yes , the problem on ur tv is the main signal board , when this board goes bad the opc light blinks , i have fix like 20 tv with this problem , now to order the right board u most look at tuner inside ur tv and get a 4 digic number follow by word main , by replacing this board would fix this problem on ur tv
Dec 15, 2010 | Sharp LC-52D62U 52 in. LCD HDTV
Sharp Aquos HD black screen. Sound but no picture. Remote will turn TV on, but will not change inputs or do anything else. Happened suddenly.
Look at the venting grills to see if you can see any white lights inside, if there is no light, the backlight inverter board may have gone out or the main power supply for the inverter board is not working. If you do see the lights then the problem can be in the main controller board.
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos lc -32da5u
Probably needs a new main unit or power supply board replaced. Most times is main unit
Jun 17, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
  1. unplug tv
Mar 15, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Computers & Internet Logo
22 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
