Question about Garden
Where can i get john deere pto switch wiring diagram x465?
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
nova2nv
  • 197 Answers
SOURCE: My 870 john deere clutch will not disengage. The
This is common for the 70 series.Clutch dics are stuck together,just short of splitting tractor you have to hit a pile of dirt with loader bucket to see if you can break it loose.
Posted on Nov 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
I have a John Deere GT275 that keeps blowing the F3 15A fuse. Any suggestions why?
Get a wiring diagrams and trace down each component the fuse powers and its wiring and find the short, no other way to fix it.
Jul 12, 2017 | John Deere Garden
John Deere x320 PTO switch not getting power. Mower blades will not engage. Replaced PTO clutch and PTO switch. Have checked seat safety switch and RIO switch as well.
Just out of curiosity check your pigtail that plugs into the pot harness. I have ran into a broken wire inside that pigtail before.
Nov 26, 2016 | John Deere Garden
JD 345 pto will not turn on.
What you need are wiring diagrams, not schematics, and you will have to inquire directly to John Deere.
Jul 20, 2016 | John Deere Garden
Wiring diagram for LX172 John Deere
Type into google john deere riding mower wiring diagram for pto switch clutch circuit then click images
May 12, 2016 | John Deere Garden
I have a John Deere 355d lawn tractor. Every time I engage blade or release brakes the mower dies out. Checked safety seat switch and its not that.
Try pulling up on your PTO switch to engage the RIO switch. If it works then there is a problem with the reverse switch is located near the directional pedals/linkage or on the transmission. Attached is a picture of the switch from the John Deere parts catalog and a wiring diagram.
Feb 13, 2016 | John Deere Garden
Wiring diagram john deere 260 lawn garden tractor
John Deere will be the best place unless you luck out and a John Deere mechanic or someone with a service manual reads this and responds.
Oct 04, 2014 | Garden
I have a john deere 420 that the pto will not engage. I do have power at the switch
You are going to need to Google John Deere 420 wiring diagram. There is a 30 amp fuse in the PTO power circuit. This provides the power to the Time Delay Control Module which has the solenoid in it. Any chance you can here the slonoid click? There, is a safety interlock switch on the seat. And everything goes to a common ground lug that may be corroded or loose. If the PTO light comes on but dim, then start with the ground. Quite a lot in this circuit.
Dec 14, 2013 | Garden
I have a John Deere l130 and the mower blades engage when I start the engine even when the PTO switch is off. Any suggestions?
sounds like you have feed going directly from switch as soon as you turn ingition to start mode ?
check wiring back from electric clutch to main switch
possible 2 wires have been placed on main switch instead of pto switch ?
or you have a crossed circuit somewhere (that is feed from another live circuit) not directly connected and its ended up at electric clutch as soon as you liven main circuit
a wiring diagram may help
check with www.johndeere.com
or www.jdparts and enter their site load your model and type
and go to electrical system and print out a copy of wiring diagarm
you may need to supply and user name and apply for password from john deere via their site apply on line
its a good site for info and parts diagrams
cheers hope it helps
paul
Aug 05, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
John Deere LX255 PTO stopped
My John Deer LX255 will not engage the blades unplugged yellow switch and cleaned spades. What should I do next?
Apr 21, 2010 | Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
