Question about Maytag Ovens
Cooke lewis oven not working
Grill is working oven not working. Yesterday my trip switch turned off and I had to put it on again would this have any bearing on oven not working.
aborcass
  • 2651 Answers
SOURCE: The oven stops working
if your light also cuts out intermittenly sounds like a loose connection, when heated moves and loses contact, def check wiring
Posted on Mar 01, 2008
BNewberry
  • 93 Answers
SOURCE: Electrolux EOB5630 oven cuts out
First thing you would want to check is, make sure you don't have any issues with the electrical connection to the oven first. Possible cuircut breaker issue.
Check these things first, you are probably going to find a loose connection somewhere. If that doesn't fix your problem.
Let me know and we can go from there.
Posted on May 15, 2008
  • 1214 Answers
SOURCE: bottom oven not working
A tripped breaker or blown fuse on an electric oven or cook-top, combined with an element that has stopped working, is usually a sign of a shorted, then blown (if the fuse or breaker no longer fail) element.
If you know how to use an ohmeter, you can pull the element, disconnect the wires from each end, then measure the resistance between each end of the element, and each element to the outer sheath.
A good element has just a few ohms of resistance between the wire connection points, and infinite resistance from the wire connection points to the outer sheath. Any readings other than that means the element is bad and need's to be replaced.
Posted on Jan 14, 2009
kachbibi1
  • 979 Answers
SOURCE: smeg oven not working. only clock and thermostat light working
It sounds like you have either one of the following things that need attention. First, turn off both breakers to the oven and then back on. Next check the wiring from the receptacle to the back of the oven. Next, check your internal fuses. Most ovens have them. Last, check the wiring to the elements and control switches. Somewhere you have a wire burned off the terminals or control switch. That smell you referred to is probably one of the wires that may be burned.
Posted on Feb 11, 2009
barkencoa
  • 3463 Answers
SOURCE: PRIMA FAN ASSISTED COOKER - FAN WORKING BUT NO HEAT?
Hi.
You will need to check the oven element, it probably needs replacing.
Please rate my solution.
Thanks.
Posted on Jul 14, 2009
Electrolux EOU5330X Ultrafan Electric Double Oven -
Sounds to me like the lower element shorted and tripped the breaker as it burned out. If you're handy at electrical troubleshooting that's where I'd start - comparing ohmmeter readings between the bad element and the one that works.
A wire short to the chassis would have a similar set of symptoms and be easier to find and fix.
Beyond that, you need a service tech.
Sep 03, 2017 | Electrolux EOU5330X Ultrafan Electric...
Hotpoint oven bu72 gave out loud bang when cooking dinner and blew trip, reset trip and whilst top oven and grill work we cannot get any heat from main bottom oven
Sounds like the element has internally shorted to earth and will have to be replaced by a qualified Techo.
While this may have caused a fright...think how lucky you are that the Safety Switch was invented as a fail safe lifesaver!
Oct 25, 2009 | Ovens
Hi.
Thanks.
Apr 27, 2009 | Bosch HBL 5032 Electric Single Oven
Oven wont work but clock still works
First make sure you didn't trip a breaker. You could have power for the electronics on one side of the 220V and that is why the clock still works. Turn off the breaker and then back on even if it looks on. If it does this again you have a sever problem that will require a service call. If the breaker is tripping it could be other than the oven and if so a new one will work ok unless itsin your wiring.
If this helps you please ratre me accordingly Good luck.
Mar 12, 2009 | Belling XOU252 Electric Single Oven
Bottom oven not working
Jan 14, 2009 | Baumatic B904SS Stainless Steel Electric...
Belling XOU252 Single Oven Trips Fuses Repeatedly
Hi.
Probably a faulty element, if you feel competent enough, disconnect the feed to the elements in turn, this should eliminate the problem.
Good luck.
Nov 20, 2008 | Belling XOU252 Electric Single Oven
Grill not working fully Oven model 660W
That is due to expansion of the element making the terminal touch the chassis, taking the earth leakage trip out.
Get your oven repaired by a competent electrician.
Sep 16, 2017 | Zanussi ZBF660 Electric Single Oven
Belling oven
you will have to replace the main oven element...
May 03, 2008 | Belling XOU252 Electric Single Oven
Ovens Logo
90 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Mack Baxter
ashburton
Are you a Maytag Oven Expert? Answer questions, earn points and help others
