Question about Toshiba TEC Office Equipment & Supplies
Toshiba tec b ip - Toshiba TEC Office Equipment & Supplies
How to change from Thermal Transfer to Thermal Direct on Toshiba TEC-SX4
Hi Ryan, refer to sections 5.2 Overview and 5.3.1 Printing Mode Selection from the following pdf manual. Hope this helps.
http://www.cmsitechnologies.com/TEC%20Drivers/BSX45TUM.pdf
May 20, 2014 | Toshiba TEC B-SX4 Thermal Label Printer
Tec sx4 network
Have you checked the port Number.
Tec use port number 8000 and the standard default in windows 9100. Either you change on your printer or in the driver.
Feb 12, 2013 | Toshiba TEC B-SX4 Thermal Label Printer
Toshiba BSX4T Printer : installed LAN card : can PING the IP ... CANNOT get the web interface HTTP with browser
To do this you need to add the ata card option with the page loaded
To do that you also need a utility to download the pages to the printer.
Aug 18, 2011 | Toshiba TEC B SX4T Printer
I want to modify ip adresse
Use notepad to write the following:
{IP;2,192,168,001,201'}
{IP;3,000,000,000,000'}
{IP;4,255,255,255,000'}
{IS;1,09100'}
{XJ;Termine'}
and print it to your printer
These will change your
IP adress
Gateway
your submask
activate and deactivate the port with an adress at 9100
and at the end display Termin?
respectiveley
Jul 21, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
Bonjour pouvez vous me dire comment installer la tec sx4 en reseau sous windows xp
Pour installer en r?seau deux solutions.
1 Installer la carte r?seaux et param?trer l'adresse ip, l'adresse passerelle et le masque de sous r?seau.
Soit sur le paneau ou en utilisant les commandes ci-dessous en modifiant les valeurs:
{IP;2,192,168,001,201'} adresse ip
{IP;3,000,000,000,000'} passerelle
{IP;4,255,255,255,000'} masque de sous r?seau
{IS;1,09100'} activation du port telnet en 9100
ou
brancher un boitier axis ou netgear sur le port parallele
Feb 15, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
How can i change the ip and default gateway of barcode printer Toshiba B-sx4?
I hope thisis understandable.
  1. Switch printer off
  2. Whilst pressing the [FEED] and [PAUSE] keys, switch the printer on. Display shows D I A G . V 3 . 1
  3. Press [FEED] button 6 TIMES or until the display shows I P A D D R E S S
  4. Press [PAUSE]
  5. Press [PAUSE]. Display shows IP Address
  6. Using the [FEED] and [RESTART] buttons, change the 1st number in the IP address
  7. When you have reached the number you want, press [PAUSE] to step to the 2nd number in the IP address.
  8. Again Using the [FEED] and [RESTART] buttons, change the 2nd number in the IP address
  9. Again when you have reached the number you want, press [PAUSE] to step to the 3rd number in the IP address.
  10. Repeat steps 8 and 9 until you have the 4 digits you want in the IP address.
  11. After the 4th number has been entered and you press [PAUSE] you can change the GATEWAY IP ADDRESS.
  12. Step through the above sequences to get the GATEWAY IP ADDRESS you want.
  13. You'll then move onto the SUBNET MASK IP ADDRESS. Same steps as before.
  14. The next and final item is the SOCKET PORT, enter this 5 digit number as above, stepping through each of the 5 elements that make up the 5 digit number.
Dec 11, 2010 | Toshiba TEC B-SX4 Thermal Label Printer
How to configure internal LAN in B-SX4T barcode printer?
  4. Press [PAUSE]
May 05, 2010 | Toshiba TEC B SX4T Printer
How do you setup the IP address on a toshiba tec b sx4t printer?
In diag mode (pause and feed key depressed switch on )
go to ip adress and change the value or use the instructions
{IP;2,xxxx,xxxx,xxxx,xxxx'} for the ip
{IP;3,xxxx,xxxx,xxxx,xxxx'} gateway
{IP;4,xxxx,xxxx,xxxx,xxxx'} subnet mask
socket port
{IS;1,09100'} for socket number and activation
{IS;0,09100'} for deactivation
Sep 30, 2009 | Toshiba TEC B SX4T Printer
Printer driver
Yes you have to have a driver or send tpcl commands
The other solution is to install a cups driver.
Mar 09, 2008 | Toshiba TEC BSX5 Thermal Label Printer
14 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
