Question about Samsung UN55D6500 55 3D-Ready LED-LCD 1080p HDTV
Why wont un55d6500 wont power on- five flashes?
Samsung LED TV no picture
What could be the most probable cause that the Samsung UN55VFXZA TV has been turning itself off ? How I can fix it?
Apr 29, 2014 | Samsung UN55D6500 55" 3D LED TV...
Red power light flashes and set wont come on
Hi
Turn off the tv for five minutes and then turn on..
Can u tell me model no and company name so that i can help u clearly
thank you
Oct 12, 2008 | Hitachi 46F510 46" Projection HDTV
Tv is just blinking
A number of the Samsung sets have this issue---do some research and several it is a jumper that needs to be removed from the power supply board. My understanding is Samsung knows about this and for many models fixes it for free.
Jun 14, 2012 | Samsung UN55D6500 55-Inch 1080p 120 Hz 3D...
Indesit dif 04 wont work it just make a humming noise and wont empty
Hello
Unplug the device from AC power outlet, and replug it after five minutes. If the problem perists, the motor of the unit is faulty, and should be replaced.
Feb 01, 2012 | Indesit Washing Machines
Computer shut down and red light flashing five times then three second pause and repeats
According to the troubleshooting guide for this model, the red light flashing five times indicates a problem in the RAM (memory), before the video subsystem is ready. You may just need to open the case and make sure the memory sticks are fully locked in their slots. If you just added new memory, it might not match the required specs.
Blank screen and the power LED flashes Red five times, once every second, followed by a two second pause, and the computer beeps five times. (Beeps stop after fifth iteration but LEDs continue flashing.)
Cause Pre-video memory error.
Solution
1.
Reseat DIMMs. Power on the system.
2. Replace DIMMs one at a time to isolate the faulty module.
3. Replace third-party memory with HP memory.
4. Replace the system board.
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01363877/c01363877.pdf
Jul 16, 2011 | HP Compaq DC5800 Small Form Factor PC...
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My tv wont turn on please help
you need to replace the capacitors on the power supply. There is a kit at the following link that repairs that. Its called the ATC 336 power supply repair kit, it contains the capacitors and instructions. Heres the link.
http://servicemanuals.vstore.ca/
Sep 17, 2008 | RCA HD50LPW175 50" HDTV
POWER/STANDBY indicator flashes five times
5 blinks means lamp driver error. I would suggest replacing the lamp.
Jun 06, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Picture wont turn on
Red LED flashes probably five times.
You have not mentioned the model no, so I have to guess it is few years old model.eg FE2 chssis or similar.
Most common reason, R618 270k ohms in power section has gone high.
Second, screen voltage control is slightly misaligned.
Third, high value resistors on tube base, normally two connected to screen voltage control pot have gone high.
You need to have some knowledge , a multi meter and soldering iron and know safety procedures before trying yourself.
Regards
capital98
Nov 30, 2007 | Televison & Video
Samsung UN55D6500 55 3D-Ready LED-LCD 1080p HDTV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
