Question about Toro LX423 20HP Lawn Tractor 13AX90RS848
Drive belt route 72102 wheel horse - Toro LX423 20HP Lawn Tractor 13AX90RS848
4 Suggested Answers
suzukiracing
  • 200 Answers
SOURCE: I HAVA A TORO WHEEL HORSE MODEL 71223, I PUT A NEW
The problem sounds like the tranny if the belt is correct.Thanks for asking and I hope it helps.
Posted on Jul 21, 2010
rohdd
  • 283 Answers
SOURCE: I want to purchase a drive belt for wheel horse
The belt part number is Toro 93-3884. Just search google for this part number.
They are around $50-60.Also you can purchase from sears . com
or here: http://www.m-and-d.com/TOR-93-3884.html?mv_pc=00015
J
Posted on Mar 07, 2011
SOURCE: I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
Give me more info on your Mower...like 10 hp, size of mowing deck, year it was built, and how many belts it has!
Hope to hear from you soon.
Joe
Posted on Sep 02, 2012
Need belt routing diagram for 2001 chrysler sebring lxi
Thanks for using FixYa.
Fig. Accessory drive belt routing-2.7L engine
Chrysler Cirrus & Sebring Convertible; Dodge Stratus; Plymouth Breeze
Fig. Accessory drive belt routing-Chrysler 2.7L engine
2.7L Engine
A/C & Alternator Belt
  1. Raise and safely support the vehicle.
  2. Remove the right front wheel and belt splash shield.
  3. Loosen tensioner locking bolt and pivot bolt.
  4. Rotate tensioner clockwise to allow enough slack to remove belt
To install:
  1. Install the air conditioning compressor/alternator belt on pulleys, tensioner in slack position, slip belt over idler last.
  2. Adjust drive belt tension.
  3. Install the belt splash shield and right front wheel.
  4. Lower vehicle.
    Fig. Installing A/C & alternator belt-2.7L engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Raise and safely support the vehicle.
  3. Remove the right front wheel and belt splash shield.
  4. Loosen the tensioner locking bolt and pivot bolt.
  5. Rotate tensioner clockwise to allow enough slack to remove the belt
To install:
  1. With the tensioner in a slack position, install the Air Conditioning (A/C) compressor/alternator belt on the pulleys. Slip the belt over the idler last.
  2. Adjust the drive belt tension.
  3. Install the belt splash shield and right front wheel. Tighten the wheel lug nuts to 100 ft. lbs. (136 Nm).
  4. Lower the vehicle.
Power Steering Belt
  3. Remove the air conditioning compressor/alternator belt.
  4. Loosen belt adjusting bolt. It is not necessary to loosen the pivot bolt on the power steering pump. There is a bushing incorporated into the power steering pump/bracket that allows it to pivot.
  5. Remove the power steering belt.
To install:
  1. Install the power steering belt on pulleys.
  3. Install the air conditioning compressor/alternator belt.
  4. Install the belt splash shield and right front wheel.
  5. Lower vehicle.
Oct 27, 2011 | Cars & Trucks
Serpentine belt diagram for 2004 camry le 4.2 liter automatic trans front wheel drive , just needbelt routing diagram please! , allready have the belt , know how to instal belt just need diagram thanks
Here is the link for ya! copy and paste in your browser good luck! http://www.autozone.com/autozone/repairinfo/specifications/specificationsMain.jsp?childCatName=Belt+Routing+Diagram&childCatId=25300467&categoryNValue=25399999&categoryNameForTitle=External+Engine&categoryName=EXTERNAL+ENGINE&childCategoryNameForTitle=Belt+Routing+Diagram#
Apr 19, 2011 | 2004 Toyota Camry
Jul 18, 2010 | Toro Garden
Need a belt routing diagram for wheel horse raider 10 lawn tractor
have a raider 10 in gravenhurst with a deck sticker that shows the belt routing......if you still need the diagram, let me know
Jul 14, 2010 | Garden
My troy-bilt 8.5 horse 26 inch wide snowblower wont move anymore.
Take the belt cover off that covers the drive pulley on the engine. You should only have to loosen two bolts. Inspect the belt to see what it looks like. I am not sure if it drives a gear box or if it turns a friction wheel that drives the wheels. If the belt looks good check for shear bolts that might have sheared off and replace them.
Dec 19, 2009 | Garden
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
I RECENTLY CHANGE THE DRIVE BELT ON MY 46 INCH
Recheck your installation, make sure you have it routed correctly and it is good and tight when in gear and the clutch/brake released. Check this with the engine OFF and the spark plug wire disconnected
Sep 18, 2009 | Garden
Replace the serpentine belt
First note the route of the belt. make a drawing.
Adjustments are made by moving the power steering pump. far right of belt system.
loosen top fixed bolt above center of drive wheel on p/s pump.
loosen bolt below drive wheel on p/s pump.
Push p/s pump to the left to loosen belt.
Remove old belt .replace following route of your drawing.
move p/s pump to right .
top of belt should have 1/2 inch deflection.
tighten bolts
The end
If you dont have belt route mail me at
andymalt61@hotmail.com
for drawing
Good luck .Andy Bartolo
Mar 17, 2009 | 1998 Jeep Cherokee
Toro LX423 20HP Lawn Tractor  13AX90RS848 Logo
103 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
