Question about Android Apps
Stylus stoped working on my 10.1 samsung tablet
Why isn't it working on Netflix?
Here is a video showing how to get netflix to work on your Samsung tablet. How To Get Netflix On Galaxy Tab 10 1 Or Android Tablet
Sep 04, 2015 | Samsung Galaxy Tab 101 Tablet...
How do i unlock your zeki tablet when you forgot the pattern
you can sign in with your google id
if it does not work hard reset is the only way
Nov 21, 2014 | EEEKit for Zeki 7 inch TB782B Tablet, Zeki...
What is a tablet
Tablets are handheld computers. Smaller than a laptop and bigger than a smartphone. Tablets are equipped with sensors, including cameras, microphone, accelerometer and touchscreen, with finger or stylus gestures replacing computer mouse and keyboard.
Examples are : iPad, Samsung Tab, HP slate.
Aug 09, 2014 | Apple Ipad I-pad
Dont get any keys on tablet
On a tablet you move ahead by swiping the screen with a finger or with a stylus. If and when you use an app the requires text input, a virtual keyboard will pop up on the tablet's screen.
May 21, 2014 | Samsung Tab Tablets & eReaders
I locked my android device and dot remember the combination
Since you did not tell us the name of it just go on google and type in the name of the tablet and after it put hard reset.
EX-samsung galaxy tab hard reset. you should be able to find method. sounds like the android system stoped responding
Jan 30, 2014 | Tablets & eReaders
When I use my samsung tablet I am getting lines on the screen as if I am writing with a pen I am not using a stylus , I am using my fingers this has juststarted happening in the last few days
Go into the Settings app. Near the bottom you will see Developer Options. Scroll down through the developer options to see if "Show Touches" or "Pointer Location" are checked. If they are, uncheck them.
Jan 02, 2014 | Samsung Galaxy BBSPHP1 Tablet PC
Tablet is frozen will not activate, plug into wall or usb tablet comes alive but no touch to turn on. Appears locked up, no way to take battery out for reset. any ideas
Try one of the following:
- Hold the power button for 10 seconds
- Hold the power and up volume for 10 seconds for recovery mode
- Hold the powe and down volume for download mode for 10 seconds
If none of these work then your battery might be completely drained and dead. I suggest you send your contact Samsung Support.
Hope this helps.
May 07, 2011 | Samsung Galaxy BBSPHP1 Tablet PC
Intuos 3 Pen/Stylus suddenly stopped working (as in dead).
Will the tablet work with the mouse? If it does not, is not working is the blue LED light on. If the LED is not working try another usb port. If the mouse works go into the Wacom tablet properties from the start menu. Select the grip pen from the tools. Click on the default button to restore the stylus to factory settings. When you press the pen you should see the pressure scale rise. You can also test the eraser pressure. You could also replace the stylus tip to see if that works. From the Wacom site you can order a new stylus or tips if it is found defective.
Apr 14, 2009 | Computers & Internet
Samsung Ulta Q1
stylus is controlled by the softwares , sensors are working fine in the pc . software problem is mpre likely then a hardware , try re-installing the OS , if it doesnt work the only you refer the company people (the manufacturers)
Nov 06, 2007 | Samsung Q1 Tablet PC
Android Apps Logo
69 people viewed this question
Top Apps Experts
Brett Duxbury
Brett Duxbury
Are you an App Expert? Answer questions, earn points and help others
