Question about Hampton Bay 24002 Ceiling Fan
How to fix a Patton U2-1803? - Hampton Bay 24002 Ceiling Fan
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Jan 19, 2016 | Patton PQH307UM Electric Utility Heater
The Patton Floor Fan I have quit working when a shirt was sucked into it and no-one was home. I am wondering if they have a fuse on the motor that can be replaced?
Most have a one-time thermal fuse wired into the motor. You would have to remove cage and fan blade, unscrew motor mounts, open motor casing, locate fuse by cutting open or sliding off the thermal sleeves, cut fuse out and resolder a new thermal fuse in. Should be able to locate replacement thermal fuse online. Can also just splice ends together but then you lose thermal protection and a fire can result. It is a good temporary fix to diagnose if you have burnt out one of the motor coils.
Oct 01, 2014 | Patton Dryers
I have an PATTON PUH 9000, it works when it want too on/off never really heating anything.As there is a RECALL on this unit, where do i get it fixed or my money back?
Here's a link to the site that has a phone number to call concerning the recall of last December.
Use it to determine if your model Patton heater was included in the recall.
http://thestir.cafemom.com/home_garden/113974/huge_walmart_heater_recall_over
There was also a recall in 1985.
Feb 10, 2011 | Patton PUH9000-U Heater
I HAVE A MODEL POH 682 IT HAS A TWO POSITION "ROCKER" TYPE SWITCH ON THE FRONT LABELED 1 & 2 . WHICH IS THE "HIGH" SETTING ? ...
It's an easy fix, so to speak. You Patton heater was recalled in December of last year. So now you are entitled to a new one.
Here's link that will give you more ino and a number to call:
Feb 09, 2011 | Patton PUH680-U Utility Heater
Is there a recall on patton heater mod puh9000.mine shorts out? thank you
Yes, there is/was a recall on some Patton Heaters, but I don't recall if your model # is one of them. For more info search Google for Patton Heater Recall Notice and you'll find the correct site.
Jan 26, 2011 | Patton Electric Heating & Cooling
What does it mean when the audible alarm comes on while using the Patton 1500?
More than likely, the alarm is a warning that the heater is not sitting perfectly level, check to make sure that it is sitting level. Or it could be a carbon monoxide warning. Open a window, just slightly, and see if that fixes the problem. Also, the appliance could be overheating, which could be a problem.
Nov 06, 2010 | Patton Heating & Cooling
Any idea where I can get replacement metal fan blades for a Patton floor fan?
I'm not all up on Patton Model#s, but this is an older unit, correct? You may try contacting Patton (Owned by Holmes now so you may have to go through them)
If they cannot help you, try www.dtvintagefans.org There's collectors there that may have parts fans that they may be willing to sell a blade.
Alternatively, you may try Grainger, as they sell an assortment of blades. You will need to match a blade to your motor though, which should be fairly easy as the Patton fans use a common McMillan motor which most attic fans also use.
Jun 08, 2010 | Patton U2-1487 Floor / Box Fan
Looking for a phone number to contact PATTON SPACE HEATER COMPANY
Patton at l-800-528-6600 ext. 1722 (Arizona: l-800-352-0458 ext. 1722; Alaska l-800-528-0470 ext. 1722)
Apr 01, 2009 | Patton Electric Patton PUH680-U Electric...
Hampton Bay 24002 Ceiling Fan Logo
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
