Question about Radio Shack 21-1926
U5 code (1) radio has code on screen U5
Error code u5
AC current detected circuit malfunction.
Jul 06, 2014 | Gree 18000 Btu 20 Seer Ductless Mini Split...
Forgot my phone password sony ericsson U5
take it to the service center. ask him to FLASH it
Jan 26, 2012 | Generic Reusable Screen Protector for Sony...
Our Xerox Phaser 4500 printer has printer cooling fan error. Call Service - Code U5
U5 00 SPF COMMUNICATION TROUBLE
U5 16 SPF FAN MOTOR TROUBLE
U5 30 SPF TRAY LIFT-UP TROUBLE
U5 31 SPF TRAY LIFT-DOWN TROUBLE
U5 40 SPF INSTALL TROUBLE
For more help visit cbr tech solutions
Feb 10, 2011 | Xerox Phaser 4500 Printer
Software of YP-U5
Hi
Please click on this link and download the software for your U5---
Samsung YP-U5 software/driver
After the link opens up select Software from the options and then select the latest versiion of the software. Please post back if further assistance is neded.
Hope this helps...
Daniel
Aug 29, 2010 | Samsung YP-U5 MP3 Player
I can't find FM radio in my samsung YP-U5
Press the button with the returning arrow at the top. The use the skip forwards and back buttons until you see the FM radio function. Press the play button to activate and once in you can use the forward and back buttons to scan for stations.
If this doesn't work, you could download emodio and update the firmware.
Feb 21, 2010 | Samsung YP-U5 MP3 Player
Sharp copier SF-2025 displays an error code U%.
Hello sir; It can be reset by power on and open the front door, press and hold exposure key while you closing front door.
Sep 29, 2009 | Sharp SF 2020 Copier
Cod-U5
U5–0: Fuser temperature dropped below specific temperature for more than 5 seconds.
U5–1: Zero crossing signal is not present
If a problem continues, check connection between MAIN PWB and LVPS. If no problems are
found, replace LVPS, MAIN PWB in sequence.
Apr 05, 2009 | Xerox WorkCentre Pro 423 Copier
On a sharp SF-2020.. I get a U5 code with 01 subcode...
u5 indicates the ADF can't communicate, make sure the ADF is pluged into the copier. MAKE SURE TO UNPLUG COPIER BEFORE CKECKING ADF PLUG. If all is good then main board is bad.
Feb 25, 2009 | Sharp SF 2020 Copier
XEROX 6110 coloer printers
Xerox 6110 Code Description A1-1 to A1-32 All indicate a paper path problem, etc. in the ADF A2 ADF exit problems A3 Irregular size documents A5 ADF interlock A6 ADF single sheet document reset A7 Platen interlock A8 ADF exit interlock C1 Tray 1 jam C2 Tray 2 jam C3 Tray 3 jam C6-1, C6-2 Jams related to duplex C6-3 Registration sensor, re tray 1 C7-1, C7-2 HCF feed problems C7-3 Tray 1 feed problem C8 Paper stays in tray or duplex or HCF C9 Bypass feed problem E1-10 to E1-25 Internal jam E1-6 Paper on registration sensor E2 Reset signal happened. Might read E-2 something else E3-30 to E4-14 Exit jam E3-6 Exit jam E4-10 to E4-14 Inverter sensor not actuated E4-15 Inverter sensor E4-40 to E4-45 Duplex entry sensor E4-6 Inverter sensor E5 Front door interlock E6-1 Tray 1 interlock E6-2 2 tray or duplex interlock E6-3 HCF interlock E7-2, E7-3 Duplex interlock E8-6 to E8-15 Duplex entry sensor F1-1 Sorter entry sensor F1-6 Sorter exit sensor F3 Paper size not available for sort/stack F5 Sorter interlock J1 Add toner J3 Replace copy cartridge J7 Replace copy cartridge J8-1 Wrong copy cartridge installed J8-2 Copy cartridge EEPROM L6 Auditron or other counter problem L8 Platen glass temperature is too high L9 Communication problem between interimage erase/edge lamps and main board U1-1 Main motor drive problem U2-1 to U2-4 Scan home sensor U3-1 Lens sensor U4-1 Open fuser thermistor U4-2 Fuser did not warm up properly U4-3 Fuser temperature too high U4-4 Fuser problem. Staying on too long U4-6 High fuser temperature U5-1 Sorter bin home switch not activated U5-2 Sorter bin home switch stayed actuated U5-3, U5-4 Sorter bin home switch U6-1 ROM problem U6-2 RAM problem U6-3 Low battery U6-4 Incorrect value in NVM. Reinitialize main board with code 20-96 U8-1 to U8-6 Problem with exposure lamp, lamp sensor, lamp board
Jan 03, 2009 | Office Equipment & Supplies
Sharp AR-5132 has a U5 error code
Check and clean all the Sensor on the ADF!
Jul 07, 2008 | Sharp AR-5316 Advanced Digital Imager...
Radio Shack 21-1926   Logo
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
