Question about Philips Philishave HQ8150 Electric Shaver
Where can I purchase a replacement rechargeable battery for my HQ8150 please?
After 4 years use the battery will no longer hold a charge. I like the shaver and would like to keep it in working order.
SOURCE: replace batteries on phillishave HQ7780
You neet torx T9 , quite cheap.
Posted on Dec 21, 2007
SOURCE: Electric Shaver will not charge
There are 4 small philips head screws deeply recessed on the rear of the razor. Unscrew these and the back half of the case just lifts off. Unsolder the battery leads and fit new battery pack.
Posted on Mar 21, 2009
brector3
  • 1602 Answers
SOURCE: How to open Philips shaver 7110X to replace batery
Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
You will find a battery for your shaver at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Feb 12, 2010
brector3
  • 1602 Answers
SOURCE: My philishave no longer seems to hold a charge.
Yes, there is a battery pack inside that can be changed. You will find replacement batteries for model HQ7740 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace them, you will need to first remove the flip up lotion cartridge cover on the back. Then remove the 5 screws there to take off the back of the case. You can then access the batteries. You will need to 'unsolder' the old ones from the circuit board and then solder in the new ones.
If you are not equipped to do this yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
Posted on Jun 04, 2010
brector3
  • 1602 Answers
SOURCE: Shaver no longer holds a charge for longer than 1
You can repair yourself if you are able to solder the new battery pack into place. You will find the correct batteries at shaveroutlet.com. See link below (you will need two batteries)
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
If you are unable to do this yourself, shaveroutlet.com can do it for you. See link below for information
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Posted on Nov 04, 2010
Testimonial: "Thank you"
Will not hold charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Nov 02, 2012 | Kodak EasyShare DX6440 Digital Camera
Battery not holding a charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.Since you did not supply details of your device and the type of battery I cannot advise where to purchase the battery.
I suggest you Google the Internet for the rechargeable battery you require.
Apr 15, 2012 | Televison & Video
I have a new refurbished kodak easyshare c160 -- the camera will not last but for one or two pictures without completely draining the batteries. i have tried about 4 new sets of photo batteries....is this...
Solution: As digital cameras become more advanced and include more features, the power needed to keep them functioning has also increased. That means that typical alkaline batteries likely won’t do more than power your camera for a few shots before running out of juice. Sometimes, your digital camera may not power on at all if the inserted alkaline batteries aren’t fully charged or powerful enough. Rather than carry along dozens of alkaline batteries for a single photo shoot, you can save money by purchasing rechargeable NiMH (nickel-metal hydride) batteries. Rechargeable batteries can be purchased with a charger that you plug into a wall outlet, and they fully charge in one to five hours depending on the charger and the type of batteries you’re using.
If you’re already using rechargeable batteries but are experiencing short battery life with your digital camera, it’s likely time to replace your rechargeable batteries with new ones. Depending on the number of charging cycles you perform (how many times you discharge and recharge your batteries), rechargeable batteries typically last for two to three years before they no longer hold a full charge. You may also ensure that you’re charging your rechargeable batteries directly before use. As batteries sit unused for extended periods of time, they automatically lose some of their charge.
There are many ways you can conserve battery life while using your digital camera, too. For starters, if your camera has a viewfinder in addition to an LCD, use the viewfinder to frame your shots and turn the LCD off because LCDs draw a lot of power. If you prefer to use the LCD, you can still conserve battery life if you refrain from looking at each picture on the screen after you take it.
Jun 13, 2010 | Kodak EasyShare C160 Digital Camera
I am in Pune 411004 in India and have purchased Samsung digital es 15 camera recently. Original 2 aa Alkaline batteries have been completely used up.when I replaced these with 2 new eveready batteries...
Jun 13, 2010 | Cameras
The unit is no longer recharging, I need to
Sorry about this but the batteries for this seem to be discontinued and are no longer available. A quick rumage around on google for a GDVD70W6 Battery 7.4V 2600mAh 456295 YOKU info from www.chsinteractive.co.uk just keeps coming back with the same answer.
Regards, James
Apr 19, 2010 | Goodmans GDVD70W6 DVD Player
I purchased phillips series 7100 on 27th Nov. 2007 and it is now not holding the charge. I have adherd to the 8hr. charging & there is nothing wrong with the supply to the razor. As this is within the...
It sounds like your batteries are no longer able to hold a charge and are in need of replacement. With all rechargeable shavers, once the batteries are incapable of holding even a minimal charge, the shaver becomes unable to be used, sometimes even wih the power cord plugged into an outlet. My Braun shavers all worked for about a year after it would no longer operate on battery power alone, then the shavers all stopped working regardless of being plugged in directly to an outlet.
As you mentioned you are still under the warranty period, I would suggest you contact the company and request warranty service for your shaver.
if you weren't under warranty, I would advise getting the replacement batteries and doing a repair yourself.
Hope you find this Very Helpful and best regards!
Sep 11, 2009 | Philips Health & Beauty
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Dead battery
Charge the battery using the supplied USB cable. The salesperson meant that the battery would last for years before it will no longer take a charge and need to be replaced.
Apr 06, 2009 | Sony NWZ-E438F Digital Media Player
Philips Philishave HQ8150 Electric Shaver Logo
42 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
