Question about Comfort-Aire HD-651 Dehumidifier
No water in bucket and humidity levles in basement high. fan sounds like it is running. comfort aire model about 1 year old. low temp model
SOURCE: Unit Runs (fan and condenser) but no water?
By condenser I assume you mean the compressor is running. Is there ice forming on the front coil?
Posted on Jan 08, 2008
SOURCE: comfort-aire Dehumidifier bhd-651
Most likely the fan motor is broke. I have seen several units with bad fan motors.
Posted on Aug 02, 2008
  • 117 Answers
SOURCE: comfort-aire model bhd501b unit comes on then
I've had to strap several buckets on with bungie cords; they shake some and the bucket full sensor thinks the bucket has been removed.
Posted on Jan 05, 2010
  • 413 Answers
SOURCE: The humidifier runs but there is never any water
If this is a refrigerant based humidifier with a compressor in it, you may be low on refrigerant or have a refrigerant leak.
Posted on Apr 11, 2011
  • 4736 Answers
SOURCE: new unit, try using in basement. nothing happen,
If you trying to remove humidity, the setting or percentage of humidity to you want to remove should be set low. it's actually the humidity that will be left in the air. In the Hot Summer months, you want lower humidity, as opposed to the Winter months, when you want higher humidity.
"Plastic cup inside the bucket" - that's got me stumped. But, I suspect, it may be a float valve to turn the unit off, once the bucket reaches the full level. The water enters the bucket through a drain tube or hole from inside the dehumidifier, above the bucket.
By best advice, since this is a new unit, that you recently purchased, is read the Owners Manual/User Guide and become thoroughly familiar with the proper operation of your Dehumidifier, as well as how to properly maintain it. As, they aren't maintenance free.
Posted on Apr 15, 2011
After 12 hours of operation, why is there NO condensate in the bucket?
units loose there efficiency over time , five years is a pretty good time for it to work
Aug 11, 2015 | Comfort-Aire BHD-501 Dehumidifier
I purchased this dehumidifier three years ago. It has been working fine up until about two weeks ago. I have the humidity setting at 40%. It is located in my basement which is not very damp. It now runs...
Jeanne, unless your unit is what's called a "Low Temperature" unit (these are designed for basement application) , that may be the problem. In addition, the air intake filter may need to be removed & cleaned.
If yours is not a Low Temp model, raising it up of the floor onto a sturdy table or counter top that can handle the weight of the unit and a full bucket of water, may solve the problem. The reason for this is in a basement, the air temp at floor level is colder than at shoulder level. Non Low temp units struggle to operate at temperatures below 65 degrees. Raising the unit up off the floor onto a sturdy table or counter top, that is strong enough to handle the weight of the unit, plus a full bucket of water, will usually resolve the problem.
I hope this information helped you and thanks for choosing FixYa.
Sep 14, 2011 | Kenmore 54501 Dehumidifier
Basement smells musty, fan won't stay on continuous
Barbara, are you running the unit in a continuous mode (i.e Using a hose to drain the unit)? Or is the water draining into the water collection bucket?
If you are not using a hose for continual drainage, the fan will not run constantly. It requires that, for continual operation.
Also, you may have the humidity extraction level set to high. Lower it to 35%. Also, remove and check the air intake filter, as it may need cleaning.
Dehumidifiers that are not Low Temp models have a difficult time operating in basement applications. Because the air temp at floor level is colder than at shoulder level. At temperatures between 40 & 60 degree F, regular dehumidifiers struggle to keep up. Raising it up off the flow on to a sturdy table, counter top, etc that can handle the weight of the unit, plus a full bucket of water can really help.
I hope this was of assistance and thanks for choosing FixYa.
Jul 29, 2011 | LG LHD459EL Dehumidifier
I have a Crosley Model # DCW405, spec.D40F-LCRF270. Last year the compressor would not kick in. I did some simple thing to get it to work. This year, i again cleaned the filter, plugged, unplugged, scooted...
It may very well be that you have the humidity extraction level set to high. Lower it to 32-35%. If you have a manual unit, set the control to Maximum. Since it's a basement application, raising the unit up off the floor on to a sturdy table or counter top that can handle the weight of the unit, plus a full bucket of water, may also solve the problem. As, the air temp at floor level is colder than at chest or shoulder level. Dehumidifiers do not work well at temperatures between 40 - 60 degrees F. Unless you have what's called a Low Temp Model. They are specifically designed for basement applications.
Hope this helped you to troubleshoot and solve the problem
Jul 03, 2011 | Crosley Dehumidifiers
Product is about 6 years old. Used in basement. Worked great until this year. Now will run continuously but collect little water. What type of service do I need? This is a 65 pint per day Whirlpool.
There is some service that you can do ... Clean the filter and the cooling coils, regularly. Check the humidity level that you have the unit set on. It may be set to low and there's just not that much humidity in the air at this time, for it to collect. From what you said, it sounds like you may have it set on continuous cycle which could account for the lack of a lot of water in the bucket. In continuous run, the fan stays ON all the time. It's supposed to do that, so that the air is constantly moving and the sensor only turns the compressor ON, if it senses a humidity level 5% higher than what you have it set for. Try running the unit on a 1 or 2 hour cycle (if your model will do that) rather than continuous cycle.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
May 18, 2011 | Whirlpool 75-Pint Dehumidifier
Compressor sounds as if its on, the fan is on, but water is not extrated from the air
If the room air is less than the set air then there is no water in the bucket because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
In addition, check to see if the air filter is dirty and/or blocked. Also, the room temperature might be too low, (below 15.5 C/ 60F) and finally, check to make sure that there is no obstruction to the unit, that might be causing poor airflow circulation.
I hope this helps you to troubleshoot and solve the problem.
Apr 28, 2011 | DeLonghi DE500P Dehumidifier
My Goldstar dehumidifier model DH304 runs,but fails to pick up any water
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
Other things that can cause problems: 1.Check to see if the air filter is dirty and/or blocked. 2. The room temperature might be too low, (below 60 degrees Fahrenheit ) 3. Check to make sure that there is no obstruction to the unit that might be causing poor airflow circulation.
Hope this helps you to troubleshoot & solve the problem.
Apr 28, 2011 | Goldstar DH304 Dehumidifier
Whirlpool dehumidifier in basement has stopped taking water into
how warm is the basement,if the temp of the basement is lower than say 70 degrees,the unit will not function,true dirty coils can have this effect also and a refrigerant leak on these will cause the same result,if the temp is low,use a fan to move the air and this will help with your humidity problem too
Apr 02, 2010 | Whirlpool AD35USS Dehumidifier
The dehumidifier is running but no water is in the bucket. Should the setting be on low humidity because that is what I want or should it be on high because that is what I want to take out of the air?
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensot from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Jan 05, 2010 | Haier HD656E Dehumidifier
The dehumidifier runs all day but there is only a little water being produced. We have humidity set at 35%, and the actual readings are much higher. This is only a year or so old. The last machine worked...
coolant may be low - warranty should be 5 years
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 10, 2009 | Fedders A7DH45B2A Dehumidifier
Comfort-Aire HD-651 Dehumidifier Logo
49 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
