Question about Dishwashers
Whirlpool dishwasher model wdf310plab4/will not drain
3 Suggested Answers
TheMazz
  • 78 Answers
SOURCE: whirlpool dishwasher won't drain? Model#DU5000xw
When it is suppose to be draining, do you hear the pump running.
If not, then the pump or controller/timer is bad. If the controller is sending power to the pump and the pump doesn't run, it's the pump. If no power is getting to the pump, then the controller is bad.
You'll need a voltmeter and know-how to diagnose this electrical problem. This is high-voltage power with water in the area. So please don't try to use a voltmeter unless you are confident of your skills.
If you do hear the pump, then the drain valve (solenoid) is the problem.
The solenoid valve and the pump are all underneath the unit. Accessibility from the front, bottom panel.
If this helps you, please select YES to one of the first two ratings questions. Thank you, and Good Luck.
Posted on Oct 13, 2009
  • 304 Answers
SOURCE: Whirlpool dishwasher does not drain. Wash arm operates correctly
Check the drain hose under your sink make sure its not crushed or kinked if you have a garbage disposal the hose should go up into it at a 90 degree angle if not 180 degrees into your sink drain line
Posted on Jul 26, 2012
My whirlpool dishwasher (GU980SCGB3)will not drain. Wash cycle works fine. Water will not drain when the cycle is finished.
Whirlpool Dishwasher Won't Drain - Model GU980SCGB3 ...
www.repairclinic.com/...Dishwasher/...-/Whirlpool-Dishwasher-won-t-dr...
My Orders. Login · Order History · My ... Whirlpool Dishwasher Won't Drain.GU980SCGB3 ... Dishwasher not draining, wont' start or not cleaning dishes properly? This video provides ... how to access... Show all parts for model GU980SCGB3 ...
Nov 04, 2015 | Whirlpool 24 in. GU980SCG Built-in...
Where is the drain located on the dishwasher model DU930PWSQO
The drain is in the bottom of the unit, right in the middle. You can find helpful information for your Whirlpool dishwasher here, including pictures, videos, maintenance, repair tips, troubleshooting guides and parts! My DU930PWSQ0 Model Overview from PartSelect com Good luck!
Feb 20, 2015 | Whirlpool Dishwashers
How do I replace a check valve in Whirlpool dishwasher model #WDT710PAYM5
The drain check valve is in the first part on your drain hose, the part attached to the drain pump. You have to remove the dishwasher from the cabinet . you will see the drain hose on the left side of the dishwasher. It is a whitish opaque plastic tube. Detach it from the pump and from the drain extension, a pan may be needed to catch remaining water. Carefully remove the loop from the plastic fill channel. Reinstall in the reverse order
Feb 08, 2015 | Whirlpool Dishwashers
Whirlpool du810
There should be a check valve in the drain hose to prevent that.
Is the sink drain clogged?
Link to video showing how to replace the drain hose and check valve. Dishwasher Repair Replacing the Drain Hose and Check Valve Whirlpool...
DU801 is not the complete model number. Find the complete model number. It should be just inside the door on the right side of the tub.
Go to sears parts direct. And enter your model number and find the part number for the drain hose of your dishwasher. The number in the video may be the correct one.
Link to searspartsdirect.
http://www.searspartsdirect.com/
Sep 06, 2014 | Whirlpool Dishwashers
Whirlpool dishwasher wdf310plab4 will not drain
If the pump can be heard running, check for blockages (filter and hose), What sort of head (siphon height) is involved ? (ie. is water running back). Do you have a "check valve".
If no no pump then ....
a) check you are at the start or end of a cycle.
b) the pump may be seized or defective.
c) machine thinks it is drained.
It is most likely the pump unit, but you will need to investigate that yourself. Download a parts book. The pump is about $50.
I gather it is out of warranty. So this is my best guess.
May 07, 2014 | Whirlpool DU1055XTS Built-in Dishwasher
Jul 25, 2012 | Whirlpool Dishwashers
I HAVE A WHIRLPOOL DISHWASHER MODEL DU890SWKU0, MY QUESTION IS: EVERYTHING WORKS BUT THE WATER DOESNT GET FULLY DRAINED WHEN CYCLE IS COMPLETE. WHAT CAUSES THIS? THANK YOU
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Whirlpool Dishwashers
Whirlpool dishwasher model DU92OQWDBO does not drain water and flapper door for detergent did not open during cycle
My Whirlpool dishwasher stop draining the water.
What do you thing is the problem? Pump?
Thanks, Henry
Jul 01, 2010 | Whirlpool Dishwashers
Whirlpool model shf 5800 will not drain completely
Did you remove the knock-out in the disposer...if not that's why you are not draining.
Jun 02, 2008 | GE Dishwashers
Did not drain after wash
My Whirlpool dishwasher model no. DU960PWKQ1 will not drain after wash. Dismantled impeller/strainer and there were no clogs.Drainline is clear.
I think motor is reversible, so there is no drain valve? HELP ME PLEASE.
Jan 13, 2008 | Whirlpool DU960PW Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
