Question about Craftsman Garden
How do you assemble the two springs on a sprint 375 briggs and stratton ?
    Problem Solver:
  • 16 Answers
The ends of both springs hook at the loop of the metal linkage connecting the governor vane and throttle shaft. The other end of the small spring hooks onto a small upright plate approximately 1 inch towards to the front of hooked end of the spring. The longer spring hooks onto a large hole in the throttle plate.
A problem that does occur is the plate becomes bent when the mower us pushed under shrubs. This drops the speed of the mower to a low idle. If this is the case then with a pair of pliers, gently twist that metal plate to obtain a RPM setting of 3,100. Don't be tempted to increase the revs to much or the conrod will break and punch a hole through the engine block.
Posted on Jun 06, 2014
5 Suggested Answers
  • 4 Answers
SOURCE: The engine on my Sprint 375 floods when trying to start
Check the float in the carb. bowl for gumming and clean your carb.. If you haven't done so already. Or you can try running a fuel treatment through your fuel. That may help you with your flooding issues. Good luck.
Posted on May 05, 2009
hunter19_46m
  • 7482 Answers
SOURCE: I have a lawn mower
Hi eugenemcmena...
Sounds like you have dirt/debris in your carburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Also check you fuel line condition after a while they will degrade and need replacment.
Make sure you are getting spark at the spark plug, to do this:
Remove your spark plug and check to be sure you are getting fire at the spark plug.
You do this by grounding the plug on the head of the engine and pulling the crank rope, if you are getting spark then:
Check/Clean/Replace your fuel filter if you have one.
Also make sure you are using fresh fuel...and oil mix if your using a two cycle mower or weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
If the mower/weedeater is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
Once you have your carburetor rebuilt that should solve your problem.
This is a FREE answer,Please take time to rate me
Posted on Jun 07, 2011
  • 316 Answers
SOURCE: govenor spring correct fitting 375 sprint
hello, If you go to briggs and strattion.com model parts search or manual,you will need engine model number,to find your parts or engine illustration,hope this helps. @@
Posted on Feb 20, 2012
dwebster766
  • 3 Answers
SOURCE: How do I change the oil on a Briggs and Stratton
take it to a lawmmower shop
Posted on Aug 25, 2012
Briggs and Stratton motor mower. Model "Sprint 375" two stroke.
pull the carby and clean it out
clean out the main jet and the blockage in the needle and seat area
check that the tank cap vent is clear
May 06, 2016 | Garden
I have a sovereign 375, the cable which goes from the Handle to the engine has broken, is there another model/type of mower that will fit? Thank you
Contact this company https://www .briggs and stratton.com/ they sell all parts for beiggs and stratton. Give them the model # of the mower and they will be able to sell you the right cable
Sep 23, 2015 | Briggs & Stratton Garden
Can I use sae 20W-50 oil in my briggs and stratton 375 sprint mower
No, it should take a straight sae 30 grade oil.
Jan 10, 2013 | Garden
Govenor spring correct fitting 375 sprint
Feb 09, 2012 | Garden
I have a Briggs & Stratton Sprint 3.75 hp lawnmower and it seems the cord is pulled almost all the way out and won't retract. How will i know if it is broken? or should I be able to wind it back up...
You should be able to Fix this yourself if your a fair garage tinkering mechanic. However...I need the engine and type number off of the engine to get you parts information. The spring is broken in your recoil. It is a matter of removing the air shroud, taking off the pulley / spool and changing the spring.
http://www.ehow.com/video_2328977_how-install-lawn-mower-starter.html
and how to tension the spring:
http://www.ehow.com/video_2328961_how-tension-lawn-mower-starter.html
There are 2 different types of springs used so having your engine model / type number is important so that you can get the right spring. One of the 2 part numbers is: 390066
Thanks for choosing FixYa,
Kelly
May 22, 2011 | Briggs & Stratton Briggs Stratton...
I have a Victor 4-stroke (sprint 375) which is 8 yrs old. Never missed a beat until yesterday where the engine now revs, then almost cuts out, then revs, then almost cuts out etc. All 'obvious' components...
You need to take the carb off and clean it out real good.i would suggest taking a bread wire and run through the passages in carb then soak in mineral spirits or other cleaning solution.blow out with air hose.
Dec 10, 2010 | Briggs & Stratton Garden
Parts list required for starter and drive gear spring assembly (engages flywheel on start). Engine model 303777.
First on the shaft goes the small felt washer, if supplied, the the drive gear, the return spring, the cap washer and the circlip. Thats it.
Aug 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Choke spring carburator assembly
how do you assemble the two springs on a sprint 375 briggs and stratton ?
Aug 14, 2009 | Craftsman Garden
May 04, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
129 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
