Question about Dell OptiPlex 760 PC Desktop
Dell optiplex 760 tower fan noise problem - Dell OptiPlex 760 PC Desktop
  • Dell Master
  • 629 Answers
Most common fan which may generate noise are the cpu fan, case fan and video card fan. if you can open the case and determine where the noise is coming from, check if the fan generating it has physical issues like loose wires or screws or if the blades are touching the plastics which may be able to adjust to stop the source of the noise. if the noise is a result of the fan spinning very fast, it might indicate a possible heat issue on the system. try updating the BIOS of your motherboard which you can usually download from the Dell's support web site then searching for your system's service tag or model. BIOS updates may include fixes or improvements for thermal handling and fan performance. if it does not help or if the issue is more physical then performance, getting a replacement would be your next step. hope the info helps.
Posted on Jan 17, 2015
    New Friend:
  • 3 Answers
Its important to try and distinguish where exactly the noise is coming from the most typical example of this is the PSU fan (Power Supply Fan). The above also is very correct but its better to eliminate each point of failure.
Posted on Jan 16, 2015
DickCanFixIt
  • 948 Answers
SOURCE: Dell Optiplex GX240 performance problem and fan noise
The fans on Dell power supplies are rather noisy and prone to failure. Find out if the noisy fan is inside the case or inside the power supply. If your computer has become slow you should scan for viruses and spyware. If the scan does not improve things it may be time for an upgrade.
The GX240 only supports up to 1 gigabyte of RAM, you should have the maximum installed. I would not spend more than $50 upgrading this computer, you can find better used ones in the $100-$200 range.
Posted on Mar 17, 2009
  • 3940 Answers
SOURCE: Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Posted on Feb 09, 2010
SOURCE: Dell OptiPlex GX620 starts up then shuts down repeatedly
Try this: remove the DMOS battery and unplug the on/off switch plug. It's the one in the corner near the power supply. To be sure follow the cable from the front on/off switch board on back to this plug. Then plug the A/C cord in, if the system boots up fine, then replace the front panel power on/off swith board. Naturally you will not be able to power off the computer using the power switch (since we unplugged it), so you will have to just pull the plug. Hope this helps. Joe
Posted on Jul 22, 2010
  • 57 Answers
SOURCE: my dell optiplex gx620 fan
Three possible conditions of fan noise.
A condition of functional computer component parts
first, an overloaded memory due to several programs installed on the desktop bacground
second, a disk in the driver compartment generating fan energy to cool the system. Caused during movie displays using the computer disk drivers, or burning disks with the disk driver. Third, an extensive use of the computer requires more fan energer cooling capacity.
solving fan over tasking
1. free up the computer memory requirements by removing malfunctioning software programs
2. perform a computer defragmentation located by clicking START, PROGRAMS, ACCESSORIES, SYSTEM TOOLS, selecting the options disk defragment
a. defragmenting redistributes files into spaces producing an effeccient memory function requiring least fan capacity.
3. perform a computer malfunct programs cleanup by clicking START, PROGRAMS, ACCESSORIES, SYSTEM TOOLS, selecting the options of disk cleanup
a. the disk cleaning removes remnants of fragmented files making performanc effective requiring least fan generate energy
conditions of disfunction condition in a component part
1. a broken component of the computer system impeding the fans effective performance
a. a foreign object in the fan compartment causes loud noise
b. a broken fan due to over heating
c. a manufacturers condition of prior computers that performed on fan cooling rather than heat sunk dispensing and obsorption
contact expert technical support
Posted on Dec 20, 2010
chiplevel
  • 656 Answers
SOURCE: When dell optiplex 760 pc
rmove the memory from the slot and clean it with a neat cloth and insert and switch on the computer if still not working remove the processor heat sink and clean it with a cloth apply some thin layer of heatsink solvent and fix them tightly also remove the cmos battery from the motherboard and switch on the computer then shutdown the computer and replace camos battery
Posted on Dec 30, 2010
Where is the power button on the dell optiplex 760 mini tower
front right there is a wide cable connected to board with front face plate.
pls check is this match
http://imgur.com/E3320RK
Dec 14, 2016 | Dell Computers & Internet
Where does a dial up modem go in a Dell optiplex 760?
The dial-up modem would install inside the computer in a PCI slot. VERY easy to install but a couple considerations before doing so... There are different sizes depending on whether the OptiPlex is a mini-tower or small form factor case. Also - you would need drivers for the modem that are compatible with the operating system you have installed on the computer.
Apr 28, 2014 | Dell OptiPlex 760 MT Desktop Computer
I have dell optiplex 760 core 2 due,i notice that when i worked on internet my computer automatically restart after some time,,,,,plzzz tel me solution
Check whether the CPU Fan is working (try to listen for Fan noise).
This is typical of CPU overheating. Detailed Memory Test can be performed during bootup to prevent PC from even booting up if there is a memory fault. There are free programs on the web to run detailed memory tests. You can use these to verify. However, one simple method to verify is to put a small fan on the air vent of the Dell and check whether your PC still has the symptoms. If it does, then the problem is not CPU heating up.
Jan 22, 2014 | Dell OptiPlex 760 MT Desktop Computer
Auto detect analog
You can try reseating Monitor Cable on both ends.
Test Monitor on another Tower/Desktop PC? Vice Versa.
Let me know if it works
Thanks
Jan 14, 2014 | Dell Computers & Internet
Opetiplex 760 mini tower how to Open to install extra network card
There should be a sliding latch on the top that pops up one of the side panels.
Feb 21, 2011 | Dell OptiPlex 760 MT Desktop Computer
760 continue to log me off while in idle mode. Have check setting in Power Option but system continue. Please help....
Do check for CPU fan spinning fast or Sound from the same when in Idle mode, it is a known issue. Please contact Dell Tech support @ 1-800-822-8965
Nov 12, 2009 | Dell OptiPlex 760 PC Desktop
Dell OptiPlex 760  PC Desktop Logo
183 people viewed this question
Alun Cox
